10-25-2017, 08:34 PM | #1 |
Front sway bar
Who sells front sway bar that mounts on A-arm existing holes like factory ? I have one that uses small L brackets on A-arms and I don't like it much.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
10-25-2017, 08:41 PM | #2 |
Re: Front sway bar
Post a wanted add for a factory bar. I did and all worked out fine
I BELIEVE IN JOHN 3:16 |
10-25-2017, 09:53 PM | #3 |
I am a Referee of life.
Re: Front sway bar
I gave $18 for one at the local pick and pull but you need the brackets that mount to the frame. A chisel and hammer or a battery grinder should get them fairly easy.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-25-2017, 09:53 PM | #4 |
Re: Front sway bar
stock 3/4 ton is an 1 1/4 bar...moog makes urethane bushings for it....think squarebody is the same
1970 short step c10 leaf spring 454 |
10-26-2017, 01:12 AM | #5 |
Active Member
Re: Front sway bar
I thought the 1.25 bars only came in the 3/4 and 1 tons starting in the late 70s. Anyways, Early Classics sells a stock style 1.25" sway bar setup. For a painted bar, bushings, brackets and hardware, $169 isn't bad, with lowered brackets. Dunno why stock height brackets are more.
http://www.earlyclassic.com/node/1161
David Larsen 1970 Chevrolet C-10 |
10-26-2017, 01:26 AM | #6 |
Re: Front sway bar
Made in china also.
10-26-2017, 08:21 AM | #7 |
Re: Front sway bar
Check out the link below and let me know what you think.
http://www.ridetech.com/products/str...front-swaybar/ This is a 1.25 inch bar with a .250 wall thickness. It comes with new poly end links, new mounts, poly bushings with Delrin inserts to reduce stiction and..it is made in America
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
