Old 10-25-2017, 08:38 PM   #1
52napco
What kind of tilt column have I bought on ebay
OK so I bought a "restored" tilt on ebay from a seller in Tennessee. Says it's a truck column
But I'm starting to have my doubts. The shift indicator isn't like my other trucks. The indicator pulls out when it moves up and down and there's no light bulb for the indicator.
It did bolt in so the shaft is the correct length but the turn signal switch has the flat connector with an adapter which would not work so I had to rewire the plug.here's a
Link to the ad and a few pics and the neutral safety switch is a little diiferent.
https://www.ebay.com/itm/67-68-69-70...72.m2749.l2649
52napco is offline   Reply With Quote
Old 10-25-2017, 08:57 PM   #2
hugger6933
Re: What kind of tilt column have I bought on ebay
Being the correct length I'd say it is a motor home column. I have a 2 or 3 of them, I think I have tilts for all of my project trucks and that number I think is seven. I think the motorhome ones are close as you can get without getting a "real" tilt
hugger6933 is offline   Reply With Quote
Old 10-25-2017, 10:45 PM   #3
FirstOwner69
FirstOwner69's Avatar
I think picture in the link below is the one you bought. If so, it looks like an original truck tilt with an incorrect gear indicator (appears to be from a van), tilt lever and turn signal lever. It also appears to have a replacement turn signal switch with a half moon adapter. I think the seller disclosed most of those discrepancies in the listing.
https://i.ebayimg.com/images/g/GGEAA...Sx/s-l1600.jpg
FirstOwner69 is offline   Reply With Quote
Old 10-25-2017, 10:55 PM   #4
MikeB
MikeB's Avatar
Screwed by an eBay vendor! Imagine that. You should get your money back and the seller should pay for return shipping. If he balks, then contact eBay. They almost always side with the buyer.
A few years ago I bought a rebuilt 79-83 column from GMtilt.com for around $360 shipped. It was perfect. But I don't think he does 67-72 columns.
I would have gone with Ididit had I not heard such good things about GMtilt.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-25-2017, 11:34 PM   #5
franken
I think the truck/van difference is stickout of the shaft from the column. Then again, I don't have a truck column now so I'm FoS. Truck columns begin right at the end of the column if I recall.
franken is offline   Reply With Quote
Old 10-26-2017, 07:04 AM   #6
flashed
I have a GM Truck tilt I bought of the parts board that I have decided not to use if interested , I never even opened the package when it came .
flashed is offline   Reply With Quote
Old 10-26-2017, 10:24 AM   #7
MikeB
MikeB's Avatar
What year range? And is it column shift?
Mike
