Old 10-27-2017, 03:12 PM   #1
Ratman74
Ratman74's Avatar
Panel truck gas cap
I have a 65 C10 panel and I have 2 Questions for the panel truck guys:
1. Do you have a vented gas cap?
2. Does anybody make the fuel hose to run from the filler neck to the tank?
Dan "Ratman" Ratcliffe
Fourth generation Chevy truck guy, raising the fifth
1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs
1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003
Ratman74 is offline   Reply With Quote
Old 10-27-2017, 11:30 PM   #2
Captainfab
60-66 Nut
Re: Panel truck gas cap
The Suburban is exactly the same as a Panel.
1) Yes I do believe I have a vented gas cap on my '66 Suburban.
2) The hose is just a straight piece of fuel filler hose for both the filler tube and the vent. The filler tube has the necessary bends in it.
Old 10-28-2017, 12:16 AM   #3
Llay R. Rac
Llay R. Rac's Avatar
My 65 suburban has a vented gas cap.
I just replaced the filler hose, its 1 3/8 inch inner diameter, 4 inches long.
a well supplied parts place should have some, its also available online but i found you had to buy a foot.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is online now   Reply With Quote
Old 10-29-2017, 05:54 PM   #4
Ratman74
Ratman74's Avatar
Thanks guys, my I thought it was the case. My panel has a standard cap and it kept "burping" fuel after a drive. I figured it was over pressurizing the tank, so I drove it the other day in semi-locked and no fuel leaks.
I have to replace the filler hose, mine has a severe kink in it. When filling I have to stop every half gallon, so it doesn't overflow.
