10-28-2017, 12:08 AM | #1 |
Excitied
I have been restoring my wife's grandfather's 63 C10 pickup since April. In the morning we plan to start the motor. It will be the first this original motor has ran in 20 years. I took the motor to a machine shop and had it rebuilt about 6 weeks ago so I hoping she runs like top......
10-28-2017, 12:16 AM | #2 |
Re: Excitied
What are you using for break in oil?
10-28-2017, 01:00 AM | #3 |
Re: Excitied
Machine shop told me to use 10w-40... Should I use something different....
10-28-2017, 01:31 AM | #4 |
Re: Excitied
Kid Use Lucus Breaking oil High in Zink will Seat Rings Better
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
10-28-2017, 08:32 AM | #5 |
Re: Excitied
We want pictures.
10-28-2017, 09:23 AM | #6 | |
Re: Excitied
If new cam, lifters were installed then you need oil with ZZDP in it. Like this. https://www.summitracing.com/int/par...1487/overview/ Or this. https://lucasoil.com/products/engine...e-break-in-oil |
10-28-2017, 11:11 AM | #7 |
But Found Her 25yrs Later!
Re: Excitied
I think this would be a good time to get recommendations for a good brand oil.
Also, be sure it doesn't run too rich for the break in.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-28-2017, 04:53 PM | #8 |
Re: Excitied
providing cam lube has been used you can use 10w40 as long as it has no anti friction coating ability. cam lube to protect the lobes, no coating type oils to allow rings to bed in.
remember to replace the oil filter when you change oil after break in. |
