Thats the Hillbilly way
Edelbrock 1411 Float adjustment ?
Does anyone have the book on the 1411 ,I need the float adj. #'s.
The 1406 book shows 11/32 " and 1 1/4 +,- 1/4 " travel. But the tip in the Edelbrock catalog show's 7/16 " and no travel figures ? Thanks
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Fix it till its broken Bill
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
#3 | |
Did you get the seat installed yet?
1411, that's electric choke 750cfm? Should be 7/16" and 1 1/4" +/- 1/4"
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Thanks ; 68LSS1
Its sittin in there, had to get the new center belt bolted in, so it will be bolted in tonight. Thanks agin for the deal.
You can also go to Edelbrock and sort through the stuff to get a .pdf of installation / adjustment instructions for certain carbs. Go to Automotove....Tech Support....then muddle your way through info for a non-specific vehiche, select carbs, then CFM, bore type, choke type, blah blah and eventually you end up at the 1411, and there is a link to installation instructions. VERY helpful.
