Old 10-29-2017, 11:34 PM   #1
DBear
DBear's Avatar
crew cab frame shortening
Hey guys, does anyone have a link to a detailed thread how to shorten a lwb frame to short box. I have read one where its detailed on where and how to shorten it with the z cut or step method. Any help will be appreciated. Thanks
DBear is offline   Reply With Quote
Old 10-30-2017, 12:29 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: crew cab frame shortening
14" in front and I believe I did 3.5" in the rear.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-30-2017, 08:21 PM   #3
DBear
DBear's Avatar
Thanks for the info, I was really looking for an old thread that showed how you map out the z cuts, but after more searching today, I found it.
Just looked at your 72 Crew build, that is looking good. I plan on starting on one after the first of the year. Would you be willing to give some pointers then? Thanks again
Old 10-31-2017, 12:21 PM   #4
daddyjeep
daddyjeep's Avatar
I had originally planned on the "Z" cut for mine, but after a bunch of research I went with the 45 degree cut. I read a couple places that cracks eventually formed coming off of the splice... even with rounded corners. There are so many guys out there that have done straight cuts with no issues, I am quite confident in my 45 degree transition lasting forever. I covered it pretty well in my build... link in sig.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
