ladder bars?
........anybody swapped out there trailing arms for a big long set of ladder bars on a 67-72 coil spring truck?...been thinking about building a set and either relocating the coils or going coil over and making the ladder bars straight instead of angled like the factory trailing arms.....
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Fabricate till you "puke"
I am in the process of building ladder bars for my longhorn, to replace the leaf springs. I wont be able to say how well it works till about next spring tho.... Your trailing arms are a pretty good setup, & you can also add the coilovers to the stock setup(just a thought). my bars are mounted on the outside of the frame rails, on the original front spring hangers......the hangers have been moved foward about a foot tho. The bars are 35 1/2" long from eye to center of the axle tube, & built out of 3/16 wall x 1 1/2" square tubing(also urathane bushed). I still need to C notch & box the frame, & set up mounts for the coil overs & track bar. Here is a linK to bolt on coilovers for the 67-72's http://www.classicperform.com/produc...pter-Kit-2.htm Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
