Old 10-30-2017, 08:00 PM   #1
Barnfind46
Barnfind46's Avatar
Trouble finding U-joint info on 14 bolt swap
First I want to thank every one for all the great info that is shared here. I am in the final stages of swapping out my rear end on my '68 C-20.I replaced it with a 2004 Chevy 2500 14 bolt rear with disc brakes and 3.73 gears.My question is did any of you need a conversion U-joint to go from the original driveshaft to the newer rear end and did you have to shorten the drive shaft 4"? The 2004 apparently takes a wider (bigger)U-joint. I would appreciate ant input on this. Thank you.
Barnfind46 is offline   Reply With Quote
Old 10-30-2017, 08:31 PM   #2
kwmech
Re: Trouble finding U-joint info on 14 bolt swap
The majority of the 14 bolt utilized a 1350 series u-joint, but your 04 may take the 1410 which has the same size cup but a wider cross shaft. So my guess would be you need a 1350/1410 conversion joint made by Neapco
Old 10-30-2017, 08:39 PM   #3
Barnfind46
Barnfind46's Avatar
Thank you sir! Sounds like a winner!
