Old 10-30-2017, 09:09 PM   #1
dawsonthompson
Pictures of Rear bag Set keeping stock trailing arms please!!!!
Just looking for pictures of bag placement with step notch on stock trailing arm or a link to a thread. I feel like i've looked everywhere just cant seem to find any pictures with people using stock trailing arms, any pictures will help
dawsonthompson is offline   Reply With Quote
Old 10-30-2017, 09:33 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Pictures of Rear bag Set keeping stock trailing arms please!!!!
Copy this whole string without the quotes " " :
" Trailing arms bags site:67-72chevytrucks.com "
Then paste it in your address bar.
Then across the top menu you should see a choice for images.
66 C20 Service Truck:
Old 10-30-2017, 11:04 PM   #3
rvrfoot
Just keep searching you will find something.
rvrfoot is offline   Reply With Quote
Old 10-30-2017, 11:20 PM   #4
dawsonthompson
thanks guys found what I needed through the first reply, sucks that some thread pictures are blocked by photo bucket now though
Old 10-31-2017, 07:38 AM   #5
LostMy65
LostMy65's Avatar
I found that if you click on the blocked picture it takes you to the actual picture on photobucket.
Old 10-31-2017, 08:07 AM   #6
LVPhotos
LVPhotos's Avatar
Goto my build page, I got start to now. Click link. Here shot of bag set up from ride tech, used same set up from stock to PB arms. Top cup takes two bolt to single all thread and spins on and hole for line. Couple flat plates.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-31-2017, 06:55 PM   #7
LVPhotos
LVPhotos's Avatar
Heres the first set up. Top/bottom stiffner plates welded and powdercoat. I used a flat plate on top as well as bottom, the cup was wider than factory plate.
Old 10-31-2017, 09:25 PM   #8
LostMy65
LostMy65's Avatar
Is there a optimum psi at our desired ride hight?
Old 10-31-2017, 09:34 PM   #9
rvrfoot
Lets get that rear frame c notched.
Old 10-31-2017, 09:38 PM   #10
raggedjim
raggedjim's Avatar
Here's an old thread with some good pics
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
raggedjim is offline   Reply With Quote
Old 11-01-2017, 07:34 AM   #11
LVPhotos
LVPhotos's Avatar
I run around 40psi rear 80 upfront but probly need a 1" spacer to get psi down in front. It already lays bumper. The rear is pipe notchef but dont get into it because shocks. Before contact the bed hits pumpkin. I say again no notch needed til a hole in bed. Layin frame will need step.
Old 11-01-2017, 07:41 AM   #12
LVPhotos
LVPhotos's Avatar
For ride hight
Old 11-05-2017, 09:11 PM   #13
dawsonthompson
awesome thanks exactly what i was looking for
Old 11-15-2017, 09:52 PM   #14
kieth
kieth's Avatar
just a note, if you are going to run tall tires, and want to run the truck lower than stock you will need to move the the trailing arms back about 1.5" and change the angle on the rear axle. adding some 4" channel between the trailing arm front bracket and the crossmember (moves the rear axle back 1.5".) when you reinstall the front brackets rotate them 180 degrees. (changes the angularity of the driveline)
kieth is offline   Reply With Quote
Old 11-16-2017, 12:47 PM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I run 45psi in my rear bags. I don’t have a compressor or tank either. No notch either.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
