Newbie Wheel question
Well, I don't have my 72 Jimmy yet but I've been on this forum for the last 5 days learning a ton so thank you all for the lessons and knowledge. Today's question is what I think is an easy one. Looking at putting steelies on the Jimmy with caps and wondering if there is somewhere that makes recreations of these wheels and caps? I've looked for originals and have struggled so far. Any help would be great and thanks in advance.
![]() Join Date: Nov 2013
Re: Newbie Wheel question
No repros made but here is a set...you better move quick....if you have the coin..
http://67-72chevytrucks.com/vboard/s...d.php?t=749615
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
A71Blazer, thanks for the lead. Is it ok to put Chevy caps on a Jimmy? Also, where do I find wheels to fit? I'm learning about these but don't want to buy the wrong thing. 4 nub, 3 nub, not sure what this all means. Thanks again.
OOPS.....sorry.... I just complete ignored the Jimmy part.....you would be wanting GMC caps....
If I instead end up going with an aluminum wheel in the 15x10 size can anyone share the offset required to clean. brakes and not have to mod anything else. Thanks.
I found originals on ebay for my Jimmy relatively reasonably priced...havent put them on yet but theyre easy to find. Gmc a little more difficult but theyre out there.
![]() Join Date: Apr 2012
I Just picked up a set of 15x8's to replace my 15x6's. not sure yet but may sell my 15x6s shown in the pic.
If your Jimmy has factory axles and brakes, I'd be looking for a 3.875" backspace in a 15" wheel. That is what all the 15x8 "factory" dealer steelies are. I don't think I would go greater than 4" without a some measurement checking.
Just bear in mind a 10" wheel is that much wider putting some extra rubber outside the fender. What size of a tire are you wanting to run? Is the Jimmy at factory ride height?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
