11-01-2017, 10:00 AM | #1 |
Moderator
Hood Lights/Signals Wiring Run
Just wondering if anyone has run their wires in the hood to hide them better. The only pics I can find on here are these - http://67-72chevytrucks.com/vboard/s...d.php?t=592648
Anyone have ideas and or pictures?
11-01-2017, 11:25 AM | #2 |
Re: Hood Lights/Signals Wiring Run
On my 61 they run up between the hood stiffener and the hood itself.
B |
11-01-2017, 12:28 PM | #3 |
I'm just glad to be here!
I don't have a picture on how I did mine many years ago, but I ran mine under the hood stiffener brace and added a couple of holes to keep most of the wires inside that front inner structure and had the wires come back out right above the sockets on the turn signal housings. Only parts you saw was coming from the hood to the firewall. Hardly even noticed the short run of wire to the lights them selves.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-01-2017, 12:58 PM | #4 | |
Moderator
11-05-2017, 05:05 PM | #5 |
I want to do the same. I will go under the hood brace.
11-05-2017, 06:54 PM | #6 |
Moderator
Then where do you plan to run the wires? Inside the hood or outside (engine compartment?
12-06-2017, 01:14 AM | #7 |
Moderator
Anyone else?
12-09-2017, 05:53 PM | #8 |
This is how I hid my wiring on my Suburban. It's been this way for quite some time, but when I get the truck done, it will look a lot cleaner and neater
12-09-2017, 09:33 PM | #9 |
It's Better With Nitro
If it works, it's all good in my book. I just finished wiring my bed and hood...here are a couple of photos of how I routed the park/turn signal wiring for my hood:
12-09-2017, 10:21 PM | #10 |
Moderator
Thank you gentlemen.
