Before and After
Is Frame level with Body?
I have a question about the differences / similarities of how the frame vs body lines line up to each other.
If I am setting up my suspention to make the truck sit level in its ride height with the body off, is the main portion of the frame sitting level with the ground, or is there a bit of rake to it compared to the body sitting level? Does the frame sit as pictured? I do not have an unmolested truck suspension for me to check this out. Please help. See picture for explanation.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Re: Is Frame level with Body?
Subscribed. This would be good info for me too. I need to set my pinion angles. Thanks.
Before and After
Maybe a bit more detail for an answer.
At ride height, is the frame level with the body line of the cab or truckbed? Like the first picture. RED LINE or is it skewed either higher at the front or rear compared to the body? like the second picture. PURPLE LINE I'm basing my inquiry on the cab portion of the frame.
#4 | |
(In the absence of any other responses, I'll take a shot):
The straight section of the frame rails are parallel with the lower edge of the rocker, as you have shown in your first post. The line drawing is representative in that regard. Now: Do you have the engine installed? If you set the frame level now, how do you know it will still be level once you have installed the engine, cab and box? Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#5 | |
I don't want to hijack the OP's thread so I will send you a PM with a follow up question. Thanks. |
Thanks, guys.
Can you see the attachments in this link? http://67-72chevytrucks.com/vboard/s...d.php?t=522180 They were previously Photophucketed but I can see them now. K
