Old 11-01-2017, 10:00 PM   #1
DT1
DT1's Avatar
Heater-A/C ducting tips & tricks...Please
I have a new set of heater and A/C ducting and I'd like to know if there is a way to expand them to fit properly. I have never been able to put them on without slitting the ends and duct taping them in place. Is there a trick to it? Do they need to be per-expanded to go on? The only thing I can think of is to push them over a conical shaped object to slightly increase the diameter so they will go together easily. Maybe wetting the ends will help. Any advise will help.
Thanks in advance!
DT1 is offline   Reply With Quote
Old 11-02-2017, 01:34 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Heater-A/C ducting tips & tricks...Please
I recently replaced all my HVAC ducts with OEM-type wire-reinforced cloth ducting. Some went on without much trouble, and a few were extremely difficult. Do it when it's warm out. I smeared a thin coating of petroleum jelly inside the ends of the ducts. Twist as you push on. Worse case, press firmly against the duct's wire with a flat-bladed screwdriver to help force it over the plastic tabs. If one end gives you too much trouble, do that end first so you can put more effort into twisting as you push it on -- with any luck, the other end of that duct might go on a bit easier.
It was a struggle but I got all mine on without slitting or taping anything.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-02-2017, 01:43 AM   #3
randy500
Twist the fitting into the duct so that the direction you twist unravels the wire, does that make sense? Twisting the opposite way constricts the opening.
For example: If looking down the duct opening and the wire twists clockwise you would want to twist the fitting clockwise to "unravel" the wire, thereby opening up the duct opening slightly.
Should slide right in if you do it that way.
randy500 is offline   Reply With Quote
Old 11-02-2017, 06:22 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heater-A/C ducting tips & tricks...Please
Take the dash out makes it a lot easier to Run the duct work. Have the ac ball's out of the dash to.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-02-2017, 08:09 AM   #5
DT1
DT1's Avatar
Good advise from all. The dash is completely gutted.
