Old 11-02-2017, 05:54 AM   #1
85raiderburban
85raiderburban's Avatar
Exclamation muddy WATER in my brake lines?
lost power to the brakes today, and came to find out this....
most recent issue since i changed the front disc brake pads last month along with spongey pedal to the floor.
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 11-02-2017, 07:36 AM   #2
grillzy
Re: muddy WATER in my brake lines?
Master cyl is shot.
grillzy is offline   Reply With Quote
Old 11-03-2017, 01:04 AM   #3
kwmech
Did you bleed the calipers out or push all the fluid in them back into the MC when you changed the pads? That also looks like a lot of moisture in the fluid
Old 11-03-2017, 08:15 AM   #4
Keith Seymore
Keith Seymore's Avatar
Is that the automotive equivalent of having "Prince Albert in a can?"
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-13-2017, 11:21 PM   #5
85raiderburban
i used a C clamp to push the caliper piston in so I could fit both pads and reinstall. Do chevys require the brakes to be bled for just putting in new pads?? i've changed pads on 4th gen firebirds and my (ex) '76 sedan deville and they never gave me this problem.
K
i guess you could say it is
Old 12-23-2017, 10:21 PM   #6
xs-style
xs-style's Avatar
Well brake lines will rust from the inside out. Brake fluid is ... I think hydroscopic is the term for it? Anyhow, it attracts water. Anytime the MC cap is opened, condensation is introduced. That combined with brake fluid change intervals that are often over looked can yield your results. Brake fluid also has a six month shelf life after being opened due to moisture exposure, but I digress.
If you ever get a chance watch it on YouTube where they do a cup test on brake fluid. They taker one cup of brake fluid and one cup of water in like take-out cups and flip them on top of each other. One leeches into the other and it's not long before u can't tell them apart, but you know the contamination is there.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
