Old 11-02-2017, 08:59 AM   #1
oldasi
Distributors, HEI vs standard point type
My '72 350/175 has had the distributor changed to the HEI type. Would like to install a factory tach, is there a different tach for HEI vs standard point type distributors ?
oldasi is offline   Reply With Quote
Old 11-02-2017, 01:18 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Distributors, HEI vs standard point type
Well there's pertronix and a few others and then there's this one.
If you don't mind foreign made.
https://www.ebay.com/itm/SBC-BBC-CHE...MAAOSwaB5Xvd2O
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-02-2017, 03:49 PM   #3
oldasi
Im told that the HEI distributor came out in '75, prior to that they had the common or standard distributor with points and a separate coil, the HEI has a coil on top of the distributor, Ive been told that the HEI distributor could be inst'd on the '72 350/175 by removing the stock distributor and inst the HEI thus eliminating the points system, IS THIS CORRECT ? Also could I use the factory tach that would have come with the common or standard distributor with points ? IS THE TACH THE SAME FOR BOTH DISTRIBUTORS ?
Old 11-02-2017, 04:12 PM   #4
Wrenchbender Ret
Yes. The GM HEI unit can replace the point type dist & coil assembly. The point type has resistance in the circuit feeding it. The resistance must be eliminated as the HEI uses full voltage. The tach can be hooked to a term in the cap next to power feed term. It is marked "tach".
Wrenchbender Ret is offline   Reply With Quote
Old 11-02-2017, 04:12 PM   #5
54blackhornet
54blackhornet's Avatar
Upgrading to HEI is a common thing on our trucks ! Installing a GM HEI is a simple plug and play with one exception, running a dedicated 12V power supply. The factory tachometer was designed to work with standard points distributor
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-02-2017, 08:22 PM   #6
kwmech
Over the years I have owned about 5-6 trucks that either had factory tachs in them or I installed a tach dash. Every single truck I had installed an HEI and changed out the end on the wire and plugged it in. Never once did I have a problem with the tach or distributor
Old 11-04-2017, 06:13 PM   #7
Don Quixote
Don Quixote's Avatar
When I went to HEI, my tach lasted about 10 seconds before dying, even with the reducer installed, I just have one bolted to the column now until I can upgrade the dash.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
