Inline 6 removal
Hey guys, I don’t see anything in the FAQ post for engine removal of I6. Can someone point me in the right direction of where to hook up chains for pulling engine /trans together ?
Re: Inline 6 removal
I dont know if it is right but when I got mine we took the valve cover off and took 2 of the head bolts out and attached the chain that way. Probably is not the right way but it worked. Just took our time.
We never use chains on inliners. We always loop ropes around them, one front & one rear. Then you can tie loops where you need your hoist to pick up from.
The two stock engine pull brackets bolt onto the head. The front bracket bolts on the front passenger side of the head and is held by two bolts (3/8"-16 x 3/4") that point from passenger to driver side. The rear bracket is bolted onto the rear on the head (the firewall side) with a single bolt (7/16"-14 x 7/8") that is aimed downward, although, not all inline 6 heads have this bolt hole milled in them. Hope this helps!
What engine is it? 235, 230 or 292?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
ok what I did was remove the coil used the bolt hole for the chain. this was a 292 on the left side I would use a forward hole here is a pic of how it worked
Bolt a chain onto the front of the head on the PS and then loop around the rear part of the manifold closest to the firewall.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
we did pull motor and trans with no problem just lifted the trans a bit ov er the radiator support
It’s a 230
Valdosta GA! I used to pick up Pecan Hulls in San Antonio & bring them to a glue plant in Valdosta down on the railroad tracks!
Any kind of bracket on each side of the motor will get it.
