i love summertime
talk about no work one day too much the next..need opinions
hey guys, i was layed off from the welding shop a while back and rode ei for a while then this week i started applying for jobs to hold me over till spring when the iron shop gets busy, well today i started at big o tire- just swapping tires for winters and balancing...just stuff like that, i get home and a place called truck outfitters called and wants to have an interview but i told em i started working today but still want to go for an interview, so im going by tomorrow after work to talk to the guy, then also there is shaw cable, a buddy can get me a job there if i want, its full time plus commission, you sit on your ass 8 hours a day calling people its 10 bucks starting. what i want your opinion on is what should i do? shaw cable is by far the best for money and its the easiest work without a doubt but its a split shift, 930-100 then 4-830, the other 2 (tire shop and truck outfitters) are straight 8 hours, outfitters is also 10 bucks an hour and i find out about the tire shop tomorrow, what should i do? go where the money is or do what i like most? im not looking for a career thats for damn sure, just something for the winter to hold me over till i go back to the shop to weld/fabricate...sorry for the rambling...lets hear what you guys think
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Formerly yellow72custom
If you are looking for a terporary job, go for the most money! Since you won't be staying there for a long time, job satisfaction isn't that important.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
68cst_ss490
go with truck outfitters, at least u will be workin on trucks, plus maybe u will get a deal on truck accessories
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
i love summertime
thanks for the quick responses guys, unless big o pays more then the truck outfitters im goin to the outfitters, but shaw cable is same wage is outfitters but its got commission on top of the reg wage, which is real good, my buddy makes about 500 a month commission...so its a tough choice
Go with what you love. Split shifts seem like they would suck!! I say go with outfitters. It gives you time to work on your truck too!!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Go for the $$$$$$$$$$$$ for a temp job!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Before and After
Don't forget about the perks of working for a truck place. Deals on parts to fix up your truck, that may be worth a few bucks a month?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
My other Love
man I wish there were jobs like that here, I am lucky to be working full time installing stereos and alarms, there is just no jobs, not even min wage, fast food, everything is taken, but hey I make 10.50 an hour
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Derek if you don't mind split shifts, go with shaw, its a cold bit#h in winter changing tires,and your dirty as hell all day, outfitters might be fine but it'll be cold to with door open and closed all day, save your wrenchin time for your own stuff, maybe cause I'm older I'd go for the cushy job, and if it gets a little slow those shops will lay you off ,just my opinion
68cst_ss490
There are lots of mechanic jobs in edmonton, i just took an offer of 28/hour flat rate. The market here is crazy. Jobs r everywhere. i left my old job to go to midas in september and they werent busy enough so i took the big $$$ at canadian tire
i love summertime
casey-im leaning towards shaw too, my mom thinks im crazy but hell if big o was more of a shop and i could learn things id probably stay, but its just changing tires and that gets old fast. outfitters is hard to say right now, ill still check it out incase shaw doesnt pan out, but im kinda stuck inbetween a rock and a hard place right now. thanks for the help guys
Derek
#12 | |
Member since 2000
![]() i worked at Cali Concept for a while and I learned alot. It also taught me that working on other poeples trucks all day made me not wanna work on mine on the weekend. i also use to do change tires in highschool, was fun but not much to learn. Since this is temp I say go with outfitters. |
#13 |
i love summertime
Hhah alex- damn you, i was hoping youd have the awnser to my problems...
#14 |
Member since 2000
Go with the money. if working on trucks with out a lift and on concrete you might want to invest on a nice set of knee pads cause concrete kills knees.
#15 |
i love summertime
yeah money is the bottom line, i dunno, ill figure it out, always have always will
#16 |
If you can sit in a heated office and be guarnteed $10/hr + commission, you need to jump on the opportunity.
I know little of the welding industry, but I do know that an underwater welder on the coast of the Gulf of Mexico (TX, LA, MS, AL, FL), you can make $65/hr USD. Might be worth looking in to taking the training necessary to make some good money for 10 years, then move back home and retire ![]() |
#17 | |
Dunno if that is true or not....just what i have always heard.
#18 |
i love summertime
lucas, from what ive heard underwater welding is one of the most dangerous jobs out there, my welding instructor in trades school did a bit but didnt like it at all, he also said that some outfits like to teach from from the get go, since its a whole different process they dont want your regular welding habits to rub off, dont know how true this is though
#19 |
Working on trucks would be better than changing tires , as you said that gets old quick . Sitting on my butt does too , only way I would want a desk job, is with a computer, so I could come in here and chat....lol... I love working on trucks .....as some has said ...the discounts would be nice . Never know who you meet in truck shops either , great job may come along. Thats my 3 cents ..... good luck with your decision .... jyd
#20 |
10 an hour plus commission may seem like a good deal but think about how many P*ssed off people there will be on the other end of the phone . People in general don't like telemarketers ( at least thats what it's sounds like you'd be doing ) Look at the National do not call registry that's coming down HAd one here in NY for quite a while and it works for us . PLus the split shift really sucks Ask my ex wife My vote is for the truck place . But hey it's your life do what you think best .
71 C10 Short Fleet coughing and sputtering down the backroads 59 Apache short fleet resto started now suspended 1884 victorian home Current restoration project 1997 GMC Sierra Z71 1973 Harley FLH undressed 1949 male body somewhat abused but still starts most mornings |
#21 |
i love summertime
hey guys, little update for anyone interested, i went to the interview at the truck outfitters, went awesome, we got sidetracked and started talking about my 67 project, the guy interviewing me had a 68 way back when, anyways i think im getting the job, i went ahead and quit the tire shop cause it was only min wage and didnt feel like doing that. im going to hopefully get this job at the truck shop and if it doesnt work out then ill go to shaw if that door is still open. btw when i was in outfitters today they had so much sweet chit, like airbags, suspension you name it, i bet i could get some killer deals working there...
