Old 11-03-2017, 09:44 PM   #1
70K GMC
70K GMC's Avatar
AMP Steps
Has anyone done this to their Jimmy/Blazer? I tried contacting AMP Steps directly and they said bc it was not a plug-n-play vehicle, they couldn't even give any suggestions.
Anyone?
1970 GMC Jimmy
LT1 w/Holly EFI
Willwood Hydroboost
70K GMC is offline   Reply With Quote
Old 12-02-2017, 02:12 AM   #2
1967GTO
Re: AMP Steps
I have installed many AMP steps on the new body GM trucks. They have a module that controls them. The module is hooked up to both posts on the battery and to each side of the door open signal wire that grounds and folds down the step. Not to hard to make that work, not sure how you would mount the step brackets to the vehicle. The ones I've done use the body to frame bolt and the body and flange.
1967GTO is offline   Reply With Quote
Old 12-02-2017, 11:33 AM   #3
70K GMC
70K GMC's Avatar
Re: AMP Steps
Good point about the body to frame/ body to flange.
I have seen them mounted to first gen Broncos and figured where there is a will, there is a way. Was hoping someone here has tried it.
1970 GMC Jimmy
LT1 w/Holly EFI
Willwood Hydroboost
Old 12-03-2017, 04:43 PM   #4
GMC-YA68
GMC-YA68's Avatar
Re: AMP Steps
http://67-72chevytrucks.com/vboard/s...t=Amp+research
Here is another thread about them. Someone would have to make a bracket to mount them to. Then obviously the wiring which I don’t see there being an issue. Just did some on my brothers f-250 and it plugs into the OBD2 to get the door open signal. It was pretty slick.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 12-03-2017, 08:18 PM   #5
70K GMC
70K GMC's Avatar
Re: AMP Steps
Thanks!
1970 GMC Jimmy
LT1 w/Holly EFI
Willwood Hydroboost
amp steps
