Old 10-29-2003, 11:20 PM   #1
BigShelby
'74 California emissions?
Here is the deal. Got a 74 4 WD 1/2 ton, 350-4v all original truck sitting in Reno, NV. The truck is mostly original with a slight performance upgrade on the engine rebuild many years ago. This is a one owner truck but not sure if it was a California or Nevada truck when purchased. If I want to title it in Orange County, CA will I have to worry about CA emissions standards on a truck that old. Did any emissions equipment exist in 74 for this truck? If so what was the equipment? At best I figure maybe an air pump, PCV, carb preheater and no cat converters. Thanks for your help.
BigShelby is offline   Reply With Quote
Old 10-30-2003, 05:35 AM   #2
TIMSPEED
TIMSPEED's Avatar
Actually, a 74 is now smog exempt in CA.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-30-2003, 01:57 PM   #3
brennvin
I was under the impression that it the excemption limit is 30 years. See the link http://www.smogtips.com/need_inspection.html
Though, I've heard from several people that over 25 years is excempt. Any source that can confirm this limit? I'm very interested since I have a -77 and I do expect to have one or maybe two more smog checks before becoming excempt. With a 25 year exemption limit I might be done already......
/Gunnar
-77 C30 Crew Cab
-53 C3100
brennvin is offline   Reply With Quote
Old 10-30-2003, 04:32 PM   #4
TIMSPEED
TIMSPEED's Avatar
When is a Smog Inspection Required?
See Them Here
Old 11-01-2003, 04:36 PM   #5
Mdapperdan
Smog
If you regester your truck in Carson City Nv. the DMV doesn't require a smog check! In Reno you will have to pay for the smog certificate.
Mdapperdan is offline   Reply With Quote
Old 11-02-2003, 07:20 PM   #6
lofat
Rollin' Member
lofat's Avatar
it was 25 then went to 30. i think this is a recent change and all the exempt 25's grandfarthered in. i could be wrong, but i have a 73 new yorker that i bought in 99 & never had to smog it.
:: 1977 C10 cheyenne ::
:: 1973 new yorker brougham :: for sale - $1,500
lofat productions
lofat is offline   Reply With Quote
Old 11-02-2003, 11:07 PM   #7
crewcab3500
DMV smog
Smog inspections are required for all vehicles except diesel powered vehicles, motorcycles, or vehicles with a year model 30 years old or older. Vehicles registered in areas subject to the biennial smog certification program are required to submit evidence of a smog certification every other renewal period.
Vehicles that are four model years old or less are exempt from the biennial smog requirements for registration renewal.
Evidence of a current smog certification must be provided by a seller except when transfer occurs between a spouse, sibling, child, parent, grandparent, or grandchild. Smog certifications are good for 90 days from the date of issuance.
The inspection is not required on a transfer if a biennial smog certification was submitted to DMV within 90 days prior to the vehicle transfer date (a vehicle inspection report may be required for proof of certification).
How old does a vehicle have to be to qualify for a smog exemption?
Vehicles with a year model 30 years old or older are exempt from the smog certification requirements.
Example: The calendar year is 2003- 29 = 1974 exempt year model
The current calendar year minus 29 equals the year model exempt from smog certification.
When a car is sold, who is responsible for the inspection?
The seller is required to provide the buyer with a valid smog inspection certification at the time of the sale or transfer. Smog certifications are good for 90 days from the date of issuance.
crewcab3500 is offline   Reply With Quote
Old 11-02-2003, 11:47 PM   #8
C-10volvo
C-10volvo's Avatar
does that apply to all states or just cali. if not whats the laws on oregon?
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 11-02-2003, 11:53 PM   #9
crewcab3500
smog
California
Old 11-03-2003, 07:21 PM   #10
rfmaster
rfmaster's Avatar
Thumbs down More on CA emmissions
I own 75 C20 with a 350-4bbl. My truck is equipped with no cats, dual ex, carburetor preheat (stove), AIR, PVC and evap can. Limits for 1974 and 1975 are very generous compared to newer cars. Table below is the old idle / 2500 RPM test
Exhaust Emission Standards
Trucks (LDGT 1 and LDGT 2):
Category Description CO (Idle) CO (2500) HC CO + CO2 RPM
% % ppm %
1968 每 72 > 4 cyl 5.0 4.0 1000 8.0 1100
1968 每 72 ≒4 cyl 5.0 4.0 1000 7.0 1100
1973 每 78 4.0 3.0 1000 8.0 1100
1979 每 83 2.0 2.0 1000 7.0 1200
1984 每 93 1.0 1.0 750 7.0 1200
1994 + 0.5 0.5 220 7.0 1200
LDGV1 light-duty gasoline-fueled trucks not exceeding 6000 lbs. GVWR (lighter pick-up trucks
and vans).
LDGT2 light-duty gasoline-fueled trucks over 6000 lbs. GVWR and not exceeding 8500 lbs.
GVWR (heavier pick-up trucks and vans, and many commercial trucks).
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
