anyway to determine approximate build date?
anybody found a way to determine at least what month your truck was built?.... I have a '72 built in Atlanta in the 138xxx's
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: anyway to determine approximate build date?
Yes. Look at date stamp on the parking brake mechanism in the cab. Should be close. Mine has 1 25 72 and is a Feb 72 built Blazer sold the first week in March 72: http://67-72chevytrucks.com/vboard/s...&postcount=180
Original dash pads, carpet, seat foam, and drive train components all have dates that closely approximate the actual build and taken together can narrow down the month.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-05-2017 at 07:04 PM. |
![]() Join Date: Jul 2016
Isn't the month and year typed on the vin sticker on the drivers door?
Carpe manana
Yes but often these are missing or, as in the case of my blue blazer, painted over. I wasn't successful in removing the paint from mine while preserving the decal despite trying several solvents.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I probably dont have anything from the factory in the truck now, but maybe the parking brake still is....I dont have the blue sticker on these new doors
#6 | |
OP could start a post asking for serial numbers and date of manufacture, prob be helpful for others too. |
#8 | |
Carpe manana
Here's the date code on my blazer bucket foam. I don't recall seeing the same on pickup buckets.
Carpe manana
Example dash pad date
in corvette land equipment usually predates the assembly of the vehicle by 1-3 months.
some of the equipment on my 68k20 dates from january to february and it was sold on 23rd of april. I think a data base would be an excellent refference |
I sent my serial number to GM Canada and they sent me the date , where it was built, the options it had . Also got info and specs on all the models they made in 69. Very interesting, I think it cost me About $75
![]() Join Date: Feb 2009
Pretty sure the door tag has that date. May depend on year.
Build sheet does as well. I think that's it in the upper LH corner (05/19/1971). For what it's worth, I was edgeucated today my intake manifold and block were built a month before the truck was built. Just a guide and indicates flow of inventory. Mike16's post elaborates.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-06-2017 at 03:07 AM. |
#13 |
Check that out............
And looks like my dash pad and intake were built a month before it rolled off the floor:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#14 |
who knew the old paint would peel off the sticker so easily?
#15 |
I created this thread http://67-72chevytrucks.com/vboard/s...d.php?t=655702 just for keeping track of real labels with the hope we could get a big bunch and make it easier for folks to determine when their truck was built.
Feel free to add yours Trey! -Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#16 |
Just did the same as 69turqGMC, about a month ago, $100. plus postage, lots of info, well worth the $100, let me know if you need the address/phone number
#17 |
Carpe manana
My understanding from other posts here over the years is that this sort of information is only available for pickups either sold and/or produced in Canada and the records for those made/sold in the US are not available.
