11-05-2017, 09:19 PM | #1 |
Need factory Heat gauge with Numbers
Does anyone make a factory looking heat gauge for the 68 gauge cluster that actually has numbers instead of the C and H? Another question is where do I get a factory heat ascending unit that I know has the same ohms as the original? Still having problems with my new 383 running hot so Im going to change these 2 things out. Your help is much appreciated.
11-05-2017, 10:30 PM | #2 |
Re: Need factory Heat gauge with Numbers
If you're running stock-style heads, the factory-style sending unit is still available. If you're running Vortec heads, board member A1971Blazer turns the stock sending unit down on a CNC lathe and does a beautiful job. PM him and he can get you one. His name is Whit and he's a really nice guy.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-06-2017, 12:54 AM | #3 |
Im running the old camel hump heads they don't have the hole between 1 and 3 cylinder so I have to install it in the intake. I just want to get the right temp sending unit and would like to find a factory replacement gauge with numbers if anyone makes one.
11-06-2017, 02:03 PM | #4 |
LMC has 2 1/6 gauge with numbers and sender
Stan 67 swb BLU MULE posted via flip-fone |
