Door Rubber Question
Hi everyone,
I am looking for some help on door seals, and was hoping someone would know if I need BOTH the cab rubber seal that goes around the door frame, and the rubber seal that also goes on the door? Or just one or the other? I don't remember there being both so I am a little confused. #3 and #4 is what I'm referencing. Thanks! |
Re: Door Rubber Question
Every original beater I've taken apart had remnants of both seals. I call the outer one (on the door) "weatherstrip" and the inner one (on the door frame) "wind lace." I usually use just the weatherstrip on the door, but when I've had trucks upholstered they will often add the inner wind lace in a matching color.
be aware that some of the new door seals are very stiff and can cause issues with the door fitment because they don't squash out well. some will say to slam the door and park the truck in the sun forever so they take a shape to fit. my buddy had that issue with brand new seals from a reputable supplier. he ended up going with a soffseal which was like night and day in comaparison. he had his doors adjusted and fit properly, painted his truck and then went to install the new seals. the door wouldn't close to fit the body and if he were to tighten the door latch to get the door to fit then he wouldn't be able to unlatch the door. he ended up replacing the seals with the soffseal units and his door closed well and sealed well. the seals need to be glued to the door so it is a pain to install the wrong part or install the right part the wrong way around (they do have a right and wrong way. best to look at the old ones before you take them off, pics of the disassembly or strip down are important).
You should have both. There are differences in the windlace that attaches to the cab I beleive 47-early 49 had a screw on retaining strip. While the late 49-55 had a channel welded to the cab that the widlace presses into.
47-49: https://www.classicparts.com/1947-Ea...ctinfo/03-105/ 49-55: https://www.classicparts.com/Late-19...ctinfo/03-106/ Also I had the issue dsraven explained with the weather stripping that glues on the door. Originally I used Precision brand and I couldn't get my doors to close. I had to tear it off and replaced it with this: https://metrommp.com/index.cfm?f=typ...20Side%20Seals |
Appreciate the responses everyone. The weather strip I bought from classic parts I believe says it needs glued. I don't see any way for a seal to press on to my 1950 cab..
The weatherstripping and windlace are different.
Here's a photo of the windlace channel in my '51 cab. I think you can get replacements here: https://www.classicparts.com/1949-54...tinfo/03-135/# The weatherstripping does get glued to the door, here's a how to video: https://www.youtube.com/watch?v=MuuZpec4rXo |
Weird , I wonder how that does anything since it's on the inside? I guess the door would butt up against it...
It does press against the door. It also covers the raw edge of the headliner if you are using a stock cardboard headliner. Unfortunately I don't have any pics of it installed, my truck is apart for paint right now.
#9 | |
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
![]() Join Date: Jan 2016
When I put windlace rubber in my 54,it cut cab noise in half
