Old 11-06-2017, 08:59 PM   #1
100%Chevy
Cleaning brown stain from white armrests?
I have a 68,C-10 (anniversary special)
The interior is gold and white.My armrests have a brownish stain on them.I don't know what caused the stain.It's not a spot but a general brown tint.
I've tried soap and upholstery cleaner but,so far nothing is working!
What will work?
Thanks,Mike.
100%Chevy is offline   Reply With Quote
Old 11-06-2017, 09:12 PM   #2
briank
Re: Cleaning brown stain from white armrests?
I have good luck with taking simple green with hot water...spray it and let it sit, then take a toothbrush with goop handcleaner on it and work that into the hot water simple green mixture.
briank is offline   Reply With Quote
Old 11-06-2017, 09:39 PM   #3
hugger6933
I use Comet of door panels and int parts it works amazing. I even use it as hand cleaner
hugger6933 is offline   Reply With Quote
Old 11-06-2017, 10:19 PM   #4
cleszkie
cleszkie's Avatar
I have had good results with Oxy-Clean laundry spot cleaner spray on my parchment vinyl and seat belts. Spray on, use a soft bristle brush, rinse and let dry in the sun. Gets just about everything out. Finish with some 303 protectant or armor all.
cleszkie is offline   Reply With Quote
Old 11-06-2017, 10:23 PM   #5
GMCGrim
GMCGrim's Avatar
I have used a product called Krud Kutter with really good results. You can get it at Home Depot.
GMCGrim is offline   Reply With Quote
Old 11-06-2017, 10:28 PM   #6
mrtoni
I stopped letting my German Shepard sit on my white upholstery. No more brown spots
mrtoni is offline   Reply With Quote
Old 11-07-2017, 12:41 AM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Could be ground in dirt, or the surface of the vinyl has oxidized over the years. On my Buick, reupholstery was the answer, but try the cleaning mentioned methods first. None of the materials for upholstery seem to be as good as what the factory did.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-07-2017, 02:34 AM   #8
Trackman101
Trackman101's Avatar
Trackman101 is offline   Reply With Quote
Old 11-07-2017, 08:15 AM   #9
67dummy
I have had some good results on white vinyl using Lestoil and hot water,it seems to loosen any built up crud that gets embedded in the grain of the vinyl
67dummy is offline   Reply With Quote
Old 11-07-2017, 08:58 AM   #10
There are some strong cleaners. Spray Nine works weally well but it will ruin plasticinterior parts. I've had good luck recently using Purple Power. I'd remove and soak on a pretty strong solution, then scrub, let dry. Lestoil and Pinesol are really strong but not sure if harmless on vinyl. Probably ok.
Old 11-07-2017, 09:43 AM   #11
100%Chevy
Thanks everyone so far!
My interior is all original materials.
It's the door armrests that are the problem.
Top and inside parts of the armrests is where the stain is.Worse on drivers side.
Picture of the passenger side---
Mike.
Old 11-07-2017, 02:52 PM   #12
weim55
Bleech White whitewall tire cleaner. When all else fails this is the stuff I use. This is potent stuff so if you use it be sure to test it in an unseen spot first and make sure he doesn't eat the vinyl or discolor. Has saved me when nothing else could do the job.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-07-2017, 04:09 PM   #13
68Gold/white
Lots'a good ideas. Not sure how durable that material is, would be my main concern.
I wonder if Marhyde makes a white vinyl dye? If they do, I'd be tempted to try some of the less aggressive stuff mention here, and spray them with dye, IF they don't clean up to your approval....
68Gold/white is offline   Reply With Quote
Old 11-07-2017, 04:21 PM   #14
harpo231
harpo231's Avatar
I would dye it . Old cloth backed material shouldnt soak, it'll rot,
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 11-07-2017, 04:28 PM   #15
bigbadchev72
People know me
bigbadchev72's Avatar
Try a magic eraser, those things work on everything!
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 11-07-2017, 04:52 PM   #16
Grumpy old man
Grumpy old man's Avatar
Armrests are heat formed foam injected thick vinyl ,There is no fabric back. That looks like UV burn and it is not dirt/grease and won't clean off . Time to redye them . after removing them from the door use a good cleaner, Then clean again using lacquer thinner to remove any gloss still left ,Then use Bulldog adhesion promoter to help bind the final color , 1-2 very light coats works better than 1 heavy one .In this case less is better .
https://www.ebay.com/itm/Klean-Strip...38.m2548.l4275
Then use Sem 15103 color coat to finish
https://www.ebay.com/itm/SEM-15103-S...cAAOSwyYFZ-vmd
http://www.tcpglobal.com/SEM-VCS-CC_3.html#.WgIig3ZOnIU
This is the closest color , an exact color match can be done by your local auto interior shop or check in your area for a automotive vinyl repair specialist in your yellow pages .
Grumpy old man is offline   Reply With Quote
Old 11-07-2017, 07:18 PM   #17
100%Chevy
The original owner before me kept it inside and I've always kept it inside too.
My wife says it is from the oil in skin that stained them.
I even keep the dash pad and seats covered when it's inside.
I got some courage up today and tried Purple Power on the drivers side armrest.Helped some so,I went to full strength and soaked it.Then, used a very soft brass wire brush on it.
Now,it's looking a lot better,but you can still see the stains,and it looks much better than the passenger side now.
Now,the wife suggests to use ammonia on it.
I'm hoping someone comes up with more ideas before I ruin one of them!
Mike.
Old 11-07-2017, 07:23 PM   #18
Grumpy old man
Your wife is right . Vinyl has pores the oil and perspiration soaks in over time and acts like suntan lotion .
Old 11-07-2017, 10:18 PM   #19
100%Chevy
Maybe it's real naugahyde.Don't they have pores?
Mike.
Old 11-07-2017, 10:24 PM   #20
HO455
Post Whore
HO455's Avatar
I second this. Used it on my Parchment GTO interior. It cleaned everything up great except for one spot on the rear seat that has never came clean to this day. I bought the car in 84.
RIP Bob Parks.
Old 11-07-2017, 10:39 PM   #21
Grumpy old man
Mike.
It takes a LOT of Nauga's
http://www.thehogring.com/2012/01/30...ber-the-nauga/
Old 11-07-2017, 11:02 PM   #22
I knew there must be a good reason the dozens of arm rests I've soaked in Purple Power never had any issues. I wouldn't think getting soaked once would cause cloth to rot, either.
Old 11-08-2017, 09:15 AM   #23
mgkgmc
mgkgmc's Avatar
Wonder if white shoe polish would work you would have to test it in a non conspicuous spot.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
