11-06-2017, 11:16 PM | #1 |
Help !!! What does this firewall wire go to
I've searched and can't find d the answer. If I had to guess I'd say amp gauge since it's a 10-12 gauge wire. Thanks for any insight truck is a 72 super with 402 and t400 trans
11-06-2017, 11:22 PM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Help !!! What does this firewall wire go to
Could that possibly be the electronic kickdown for the THM400? My 350/350 72's don't have that wire...Can you trace it under the dash?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-06-2017, 11:26 PM | #3 |
400 kick down is orange wire by distributor
11-06-2017, 11:30 PM | #4 |
Does it have factory tach or auxiliary battery setup? My trucks with factory tach dash has the wire coming through firewall like that. I believe my truck with auxiliary battery also has a wire like that. I will have to double check it.
Michael |
11-06-2017, 11:34 PM | #5 |
No tach or auxiliary battery
11-06-2017, 11:42 PM | #6 |
Any special options listed on SPID that require wiring?
Michael |
11-06-2017, 11:54 PM | #7 |
Does it go to a relay above the horn relay? If so, it's part of the TCS, and you can eliminate it. Mine comes through the firewall in the same place, and it took me a while to identify it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-07-2017, 12:23 AM | #8 |
I wonder if that was a big block location or maybe a Cheyanne location for the TCS? I'm wondering because the TCS wire in my SB 72 went through the firewall block, it was a 10ga pink wire. I discarded all the TCS components and used that wire for the HEI when I rebuilt the SB.
11-07-2017, 12:45 AM | #9 |
I have a wiring harness on my 72 in that same spot, but it has several wires in it, including the TCS wire and some others.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
11-07-2017, 02:33 AM | #10 |
That spot was for the factory aux. tank on my 72. I think the wire was dark blue or purple (colored blind). I've since pulled it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-08-2017, 01:37 AM | #11 |
I've seen the TH400 kickdown wire on pre 71's in that location, or close to it.
11-08-2017, 09:32 AM | #12 |
The wire I have coming through at that location is for the gas gauge switch for the NL2 optioned auxiliary fuel tank.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
11-08-2017, 10:19 AM | #13 |
All about them K’s
My K20 is the same
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
