Should I have my cab blasted?
I have disassembled my 67 cab now. I will be fabbing brackets for my new dash and AC components in the next few days. After I get that done, I want to get the cab ready to paint. The local sand/concrete supplier has a sand blasting service. Would this be a good idea or will it damage the cab? What about media blasting? Not really sure what that is or if it is offered there. Just looking for opinions on the subject. Thanks
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80 2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc. 2003 Tahoe Z71 Silverado front clip |
Fabricate till you "puke"
Plastic media would be a lot more "freindly" with the tin. We had a guy in my area blasting & stripping paint. His thoughts were to stip it with plastic, then go over any rusty spots with the sandblaster. I am sure there are guys stripping with sand..... but you have to be carefull not to warp the tin. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Half a bubble off!
I had my inner fenders sandblasted while my truck was apart, and I would not do it again, too much pitting from the sand. I couldn't imagine doing that to a cab. Maybe a frame, but not a cab. Media blasting is a little kinder to the metal.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
i have a friend sand blasting the cab to his 64 F word but i have no idea how it will turn out.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
So the media blast is a plastic material? I will call the place and see if they do that too or just sand. If they don't I will find somewhere else to get it done.
Southern Bowties
HEY! I'm from Broken Bow, small world! I just had my floor and top of cab sandblasted when I had paint job done. If you're gonna do it, do it before u install anything inside. I vacuumed sand for weeks before I got it all out.
Go Savages!
1972 Cheyenne 350/350 |
Merciless Butcher
I had my 69 Camaro convertible stripped with plastic media. Well worth it. I still found little pieces of plastic everywhere. But it is way better than sand. Sandblasting can create lots of heat and possibly warp a panel.
Your Bought And Sold....I Got Your Soul! |
If you have the money have it acid dipped. Second choice would be powder blasted. Last choice would be sand blasted.
What ever choice you chose, an etching primer is highly recomended once you have bare metal. Then you will be able to slick out the metal and get ready for paint. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Media is the better way to go..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
yeller
Soda blasting IMO is the best way to strip metal. It doesn't heat up the metal, pit it, or wharp it. The others are right, straight sandblasting will do more harm than good...but it is great for chassis and its components.
Dipping is also good, but if you go that route and spray primer the cab...you will miss areas since dipping gets in EVERY little nook and cranny whereas a spary gun cant....thus causing bare metal to be exposed and rust. -Jeff here is a closeup pic of my sandblasted chassis... |
yeller
and here is a pic of my sodablasted cab (epoxied in the pic). No pitting or damage of any kind from stripping with this method.
Life is Good !
I had my cab sand blasted, and the guy that did it did a great job ! He stood back a bit and blasted it. Came out great !
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
