Old 11-07-2017, 08:31 AM   #1
67dummy
67 4x4 questions
Did 67 1/2 ton 4x4 have a factory 3 speed manual column shifted transmission? If they did are they specific to that vehicle and are they around? What transfer cases can be used in 67 1/2 ton? Looking at 67 truck missing engine,trans. and transfer case and looking for options for drivetrain.
67dummy is offline   Reply With Quote
Old 11-07-2017, 08:50 AM   #2
BLT gmc
Re: 67 4x4 questions
I can answer the tcase question. The Rockwell T-221 was used in both the 67 Gmc and chevy. These are hard to find in excellent/rebuilt condition. Gaskets have to be hand made. Bearings are aveilable, not as a kit. They have to be ordered separately. The rear idler shaft bearing is a real pain to find. Good gears and shalfts are made out of unobatanium.
Lots go with the 205, mainly b/c of the above reasons.
BLT gmc is offline   Reply With Quote
Old 11-07-2017, 02:42 PM   #3
weim55
Yes the column 3 speed was standard on 4x4 '67s. It is one rare bird as most 4x4 were ordered with the granny low SM420 4 speed. I had an original 250 six 3 speed 4x4 K10 30+ years ago. The transmission is 4x4 specific (output shaft and extension housing) but I can't for the life of me remember which transmission was in the truck, Saginaw or a Warner (??) As rare is that transmission is i'd be willing to bet somebody on the board here could set you up with the pieces to return the truck back to original.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-10-2017, 09:15 PM   #4
Vero67
I have a 67 K10, it came with the three on the tree, 3rd gear was wiped, so I pulled the old style Saginaw trans and put a SM465 in it. I used a later adapter and kept my T221. New couplers for the SM465 to T221 are impossible to find. I cut down a NP205 coupler and matched up seals to make up the diameter difference. NO leaks. This board is a great reference.
Vero67 is offline   Reply With Quote
Old 11-10-2017, 09:20 PM   #5
Vero67
Also the vin will start with a K not a C. Rare find.
Old 11-10-2017, 09:27 PM   #6
BLT gmc
Vero67- i have saved and lok at your "rockwell t-221 lives" thread quite often. Bruce
Old 11-11-2017, 09:02 AM   #7
Mike C
Mike C's Avatar
My opinion, but you would be crazy to try and get all of those parts that are missing on what is a fairly hard to come by combination.
Just get an SM465 and NP205 from a later truck. Easier to get, stronger, more reliable, and more flexible with the granny gear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-11-2017, 11:57 PM   #8
palallin
The NP 205 is not stronger or more reliable than a T221. Parts may be easier to kind, but there is nothing wrong with the T221's low gear, either.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 11-12-2017, 12:52 PM   #9
Mike C
Mike C's Avatar
No beefs with the 221 from me, but he is missing all the original engine, trans and T-case. Just WAY easier to get that combo from a square body and move forward from there.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-12-2017, 01:32 PM   #10
Vero67
I believe you need to move cross members and the driveshaft center bering mount when converting to the 205
Old 11-12-2017, 02:18 PM   #11
countr
countr's Avatar
I have a 67 4x4 that I am rebuilding and need help on the original engine that it came with. it is a 4 speed and believe the drivetrain is all original. that would make it a SM420 AND T221. But not sure what engine. I att. the cross member and Vin if someone can help.
Thanks Russ
countr is offline   Reply With Quote
Old 11-12-2017, 04:10 PM   #12
Vero67
is the sticker on the glove box door? Was the radiator still in it?
Old 11-12-2017, 04:13 PM   #13
countr
countr's Avatar
No sticker, yes radiator is still there. I will get a picture.
Old 11-12-2017, 04:14 PM   #14
Vero67
s denotes 6cyl.
Old 11-12-2017, 04:15 PM   #15
Vero67
search vin decoder on this site.
Old 11-12-2017, 04:21 PM   #16
countr
countr's Avatar
Thanks, I was not sure with the offset cross member.
Old 11-12-2017, 04:25 PM   #17
Vero67
googled the cross member, it says offset was for a 292.
Old 11-12-2017, 04:28 PM   #18
countr
countr's Avatar
Vero67 thanks for the lesson (this site is great!!!). That is what is going back in it. (JUST GOT TO FIND A GOOD ONE) Thanks Russ
