Old 11-07-2017, 11:04 AM   #1
SunSoaked
SunSoaked's Avatar
Nv4500 swap, bellhousing support rods?
Getting ready to swap the 350/208 in my 85 k20 with my 4500/205 setup. I noticed the factory has 3 support rods (2 from bellhousing to motor mounts- 1 from back of engine block to
t-case) from the bellhousing to the trans/t-case. The AA housing does not have bosses for these to mount too. What is thier function and will it hurt not having them?
SunSoaked is offline   Reply With Quote
Old 11-07-2017, 01:40 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Nv4500 swap, bellhousing support rods?
that's not technically the bellhousing..thats the inspection cover...so they can't hold much....but I've never seen anything like those....I don't think it'll hurt to not have them...I tried quick google search but didn't find anything
Old 11-07-2017, 02:48 PM   #3
SunSoaked
SunSoaked's Avatar
Correct- inspection cover. Searching the site I found a few threads on it. Seems they were only on the automatic transmissions and possibly the 4wd (aka K Case). I could be wrong but, it was an attempt to keep the auto cases from cracking ( assuming frame flex plus the weight of the t-case?). In any case, I don't think ditching them in my situation will hurt. That cast iron 4500/205 case won't be easy to crack.
Old 11-08-2017, 12:54 AM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I did still keep my th400/np205 support rod with my nv4500 swap.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
