Front Air Bags
I have a 64 C10 that I have installed a 84 front cross member with 2 1/2" drop spindles. My goal is to have a smooth ride with no scraping or bottoming out. Will air bags accomplish this for me? My plan is to bag the rear and add sway bars front and rear.
Thanks for your input. |
Re: Front Air Bags
Depending on tire height, you'll run into inner fender clearance issues before the crossmember is bottoming out on the road. My '66 was static lowered with 215/75-15 tires and they scraped the inner fenders over bumps before the crossmember ever bottomed out. There was around 1.5" between the tire and inner fender, had to pull one of the fender bolts out to keep the tip of it from digging into the tread over bumps. With bags you can set the ride height higher though, and drop it when parked.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: Front Air Bags
Thanks for your helpful information.
