Old 11-08-2017, 08:46 PM   #1
Steeveedee
Who Changed This?
Steeveedee's Avatar
Cam Choice
Looks like I'm going to have to rebuild the 402 in my '70 truck. It needs valve guide work for certain. I haven't checked compression yet, as my hands haven't recovered enough from the surgeries (carpal tunnel) to do it. I'm just doing a little groundwork ahead of the fun. It's been punched out once, but I won't know how much until I pull a head and mike the block. I'm hoping for one more bore.
In any event, I'm thinking roller cam instead of flat tappet, to get away from worrying about oil. So, does a roller cam yield more HP for the same grind? Seems like reduced friction would make some small difference. My application is towing a 6k pound travel trailer, so I don't want anything rumpty, I need low end torque, not high revs. If there is an insignificant gain (for the money), I'll just stick with flat tappet.
Any thoughts?
~Steven
Simi Valley, CA
Old 11-08-2017, 09:04 PM   #2
trac209
Re: Cam Choice
Roller cams do offer friction benefits as well as they just function better and due to the way they are made and how they work. Engine masters did a test of two cams that were very similar and it was around 40hp just for the cam swap iirc
trac209 is offline   Reply With Quote
Old 11-08-2017, 09:29 PM   #3
Mike C
Mike C's Avatar
Re: Cam Choice
Big block Chevy's are notorious for cam lobes going flat anymore. If even one flat tappet cam fails, you would have been better off with the roller.
I just built an L36 427 for my 69 short bed. It has the big oval closed chamber heads, so figure 10:1 compression or just a bit more. I plan on running through iron manifolds and want a hot street truck not a daily. I chose the smallest Comp Nitrous roller. It has 113 deg lobe separation and 224/235 duration at .050. I am hoping the nitrous grind will bring the most out of the motor running through iron manifolds. While I think this will be a great street cam for MY application, I would suggest you stay below 220 degrees .050 duration on the intake for your 402.
Look at the computer controlled retrofit Comp roller. 210/220 at .050 on 113 lsa. Or even same grind on 110 lsa would be great with carburetor. I would call Comp as they have grinds that aren't in the catalog.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-08-2017, 09:52 PM   #4
BCOWANWHEELS
Re: Cam Choice
Melling hydraulic towing cam
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-09-2017, 11:59 AM   #5
weq92f
weq92f's Avatar
Re: Cam Choice
You should go out to Comp Cams site and download CamQuest. It's kinda fun to play around with to get ideas on what may/may not be a good choice...
It's free software:
http://www.compcams.com/downloads/register.asp
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-09-2017, 12:12 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Cam Choice
Thanks for the replies, folks.
I'll download that comp cams s/w and run it.
~Steven
Simi Valley, CA
Old 11-09-2017, 01:01 PM   #7
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Cam Choice
Take a look at the Lunati cam choices. They offer a good variety of roller and flat tappet cams. I have a semi-radical roller in my professionally built 396, and while the builder didn't select the cam profile I wanted (low rpm torque), the cam he selected turned out very well and will get better when I convert over to Fuel Injection shortly. They selected a cam based on my truck and what I reported to be "fact" on the truck setup. (gear ratio, tire size, transmission, stall converter, etc.) My mistake was not verifying everything and finding out after the fact, the PO info was hugely wrong. My shop did a nice high quality build, so I am not blaming them.
My setup:I have a 3.07 posi, not a 3.73 as I was told, a 1800 stall, not the reported 2500, etc. So my cam is kinda wrong for my use/setup, but I am not going to change just yet.
Make sure you talk with the vendor you choose and give them facts about your setup and intended use. That way they can get you a proper cam setup that will meet your needs and you can have fun instead of having to piecemeal a solution like I am doing now.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 11-09-2017, 01:35 PM   #8
weq92f
weq92f's Avatar
Re: Cam Choice
Using the CamQuest...
Right now for my 402, 063 Iron head/700r/3.73 top end build I'm looking at:
Both these are Hydraulic roller cams..
Comp XR 264HR Daily Driver to Mild Performance, Strong Torque, Good Mileage 1200 to 5200 264degree, .51 lift, 112 lsa
and
Comp Magnum
270HR: Daily driven street machines. Works with stock converters. Likes headers. 396 needs 3.55-3.73 gear. Very slight rough idle.1800 to 5000 .56 lift, 110 lsa
-klb
Old 11-09-2017, 07:54 PM   #9
Mike C
Mike C's Avatar
Re: Cam Choice
I think either of those would be good. They should both be OK with stock converter and gears with a big block.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-10-2017, 10:59 AM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Cam Choice
Retrofit roller lifters cost a grip of cash. Probably worth it in the long run though.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-10-2017, 01:24 PM   #11
jocko
jocko's Avatar
Re: Cam Choice
Can’t see the links at the moment - it’s worth ensuring you’ll maintain sufficient vac for pwr brakes.
Old 11-10-2017, 02:55 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Cam Choice
Gary
The retro roller in my 400 sb is on its 3 rd go around.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
