Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-10-2017, 12:13 AM   #1
wahl4m
64-66 slave -pwr steering -cut-off assembly -f/sale
i cut this off a parts gmc ? carryall -1/2 ton - has no pump stuff -has all brackets -including hose grommet assembly 7 hoses -see pics -can ship -might be heavy? $100.00 ??
wahl4m is offline   Reply With Quote
Old 11-10-2017, 01:03 AM   #2
aotte1
Re: 64-66 slave -pwr steering -cut-off assembly -f/sale
Will you do $80 for it? I will take it. Do want the cast iron bracket that ram mounts to.
Do not need frame, fender bracket, tie rods
Les
aotte1 is offline   Reply With Quote
Old 11-10-2017, 04:21 AM   #3
1960chevypanel
Most of the weight is in the steering box, which is the same as the manual box.
1960chevypanel is offline   Reply With Quote
Old 11-10-2017, 09:47 AM   #4
wahl4m
BUT before it is shipped -i will remove the cut-off frame piece !! if you see in the pics there is some steering linkage attached ! thanks mike
Old 11-11-2017, 02:31 AM   #5
aotte1
Mike,
My zip code is 42701.
Also, any history on these parts C10 or C20; year; Chevrolet or GMC.
What condition is the steering box? Deciding whether to have you ship it?
Thanks,
Les
Old 11-11-2017, 03:09 PM   #6
GMCNUT
GMCNUT's Avatar
Gotta keep the pitman arm if you don't take the sector - specific to PS to don't let that stay behind if you don't take the sector
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
