Old 11-10-2017, 12:14 AM   #1
tjsblazer
tjsblazer's Avatar
Balancing factory Steelie rims
I have a set of freshly powder coated 8" wide steelie rims.
They are going on a full restoration. I'm not really wanting to use the regular silver lead hammer on weights on the outer rim of the wheel because of appearance.
What are my other options? What have others done? It is going on a 4x4 with 33" tires.
thx.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 11-10-2017, 01:02 AM   #2
Killer Bee
Killer Bee's Avatar
Re: Balancing factory Steelie rims
balancing beads and centramatics offer continous dynamic balancing to compensate for rocks, mud, snow, etc. that builds up and flings off..
fixed weights can sometimes be clamped on inboard rim edge or taped on.. taped weights are vulnerable to road hazards and peeling loose so extra surface prep and or edge sealant may be required..
good luck!
Killer Bee is online now   Reply With Quote
Old 11-10-2017, 02:10 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
You can use conventional weights on the inner wheel lip only.... none on the outer lip. Any decent tire shop should be able to do it, just ask 'em.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-10-2017, 07:34 AM   #4
I just put weights on the inside for a clean look. But my '72 has white 8" steel wheels and it has conventional lead weights because it's not a custom truck and the weights are just as appropriate now as when these trucks was new.
Old 11-10-2017, 10:15 AM   #5
hewittca
hewittca's Avatar
Agreed there. I was originally wanting to make sure I had no weights on the outside, but the tire shop could not get my wheels balanced without them. After they were on, I realized they didn't look too bad and then I thought, well that's how they've always been balanced so if I'm going for a stock look then this fits right in.
I've also tried the tire beads in the past, but on my much lighter VW Beetle because no one could balance the wide 5 lug pattern on those. I'm not sure if there were any vibrations without them because I never drove it without, but I can say there were at least no vibrations with the beads in the tires!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 11-10-2017, 10:22 AM   #6
jjzepplin
jjzepplin's Avatar
I had the beads on 36" Super Swampers and they worked well.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-10-2017, 11:44 AM   #7
BLT gmc
Balancing beads all the way. tire/wheel is more likely to b e balanced than fixed weights, esp if the is mud dirt debris on the rim/tire
BLT gmc is offline   Reply With Quote
Old 11-10-2017, 01:09 PM   #8
chewychevy67
I too did weights on both sides of my powder coated rims. In my opinion it's the way it was done back then and haven't heard a single person comment on them so its a non issue for me.
chewychevy67 is offline   Reply With Quote
Old 11-10-2017, 01:20 PM   #9
jocko
jocko's Avatar
I try to have them balanced on inside lip only. If the shop can’t get there with that approach, then the outer lip - yes that’s how it was done in the day, but that doesn’t mean it still doesn’t look better without em.
Old 11-10-2017, 01:54 PM   #10
Rfisher
I just went through this two weeks ago. Opted to have the weights placed on the inside only. I'm happy with the fresh clean look.
Rfisher is offline   Reply With Quote
Old 11-10-2017, 03:41 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I’ve had the wheels balanced on the inside only on every vehicle I’ve ever owned. Zero issues.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
