Old 11-10-2017, 09:57 AM   #1
Cam1968rsss
1972 Chevy Short Bed Driveshaft
Hi, would anyone know if a one piece driveshaft out a short bed 1973, with a turbo 350 trans (short tail shaft) would fit a 1972 with the same transmission?
Eddie
Cam1968rsss is offline   Reply With Quote
Old 11-11-2017, 08:53 AM   #2
Re: 1972 Chevy Short Bed Driveshaft
Honestly, with driveshaft lengths, I never trust anything but measuring yoke to yoke on the truck and driveshaft. I have gotten lucky and had shafts just work when doing swaps to measure and have one made longer or cut one shorter. It "should" work since frame length differences are all ahead of the cab, but does the engine sit more forward?
How does your truck sit now? Engine/trans in position and rear mounted? I'm waiting till I set engine/trans in the frame before thinking anything about a driveshaft on my shortbed. I'll do one piece, too.
Old 11-11-2017, 08:59 AM   #3
Mike C
Mike C's Avatar
What Tim said.
But more specifically, NO. The drivetrain is mounted in a different location, the wheelbase is different, (117.5 versus 115). And more importantly, is your truck lowered? A 1 piece shaft will not work with the 67-72 trailing arm crossmember (and it is in leaf spring trucks too) with stock height suspension.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-11-2017, 05:49 PM   #4
diggerbob
diggerbob's Avatar
Originally Posted by Mike C View Post
What Tim said.
What? I have a one piece drive shaft in my 70 short bed and my suspension is at stock height.
diggerbob is offline   Reply With Quote
Old 11-11-2017, 09:22 PM   #5
Mike C
Mike C's Avatar
Wouldn't work in m y 69. At droop the driveshaft would have hit the crossmember. I guess a good example of not all trucks sit at same stock height.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-12-2017, 09:36 AM   #6
How close is the shaft to the cross member? A comfortable distance to allow for droop? Most times a 2wd rear doesn't do much drooping with compressing (from weight) being the main concern. Just curious how the clearance is. A assume the truck originally had a 2pc shaft, correct?
