Different heights after lowering?
72 C10. 4” drop springs in rear. Shock relocate. There’s a difference of a little over 3/4” from D to P sides. No big deal, or did I screw something up? Thanks
#2 | |
Re: Different heights after lowering?
This is why I always take measurements before any work is performed. Those details help answer whether the problem was pre-existing (possibly worn body bushings or tweaked frame) vs a possible result of the install.
![]() Join Date: Apr 2013
I ended up with about 1/2" difference on my 72 C. I used CPP coils and they didn't seat the best in the front. I assumed it was due to that.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
Drive it a bit and see if it settles it’s common for chevys to lean to the driver side
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Weight differences from right to left can play into this, and so can control arm bushing bind. Those two things are the biggest contributors to this problem.
