Old 11-10-2017, 10:17 PM   #1
Marcus4800
Steering Column ????
Does anyone know if you can buy a new steering column for a 63 C10 with a 3 speed on the column
or does anyone a rebuild kit? Thabks,,,,
Marcus4800 is offline   Reply With Quote
Old 11-10-2017, 10:43 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: Steering Column ????
They don't make new manual columns for out trucks. I replaced mine with a I did it and installed a T5 trans with a floor shifter.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-11-2017, 12:12 AM   #3
Captainfab
60-66 Nut
As already said, there is no such thing as a new column for the '60-'66 trucks. You can purchase the individual parts and rebuild your original steering column.
Old 11-11-2017, 12:58 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Yep, aftermarket only (like Ididit).
Old 11-11-2017, 10:21 PM   #5
cp_66_c20
cp_66_c20's Avatar
You can use a column out of a 70s truck with a 3 on the tree but the linkage has to be adjusted correctly. It wouldn't be worth the work (my opinion). You would be best to go with a floor shifter and regular column or something like that. There are plenty of options though.
cp_66_c20 is offline   Reply With Quote
Old 11-11-2017, 11:46 PM   #6
DPowers
DPowers's Avatar
Or you could become a supporting member and that would give you the option to do a Want To Buy post.
DPowers is offline   Reply With Quote
Old 11-12-2017, 09:24 AM   #7
meinolf
hi marcus, that is also my problem I've also 63 c10 I want to change my steering column for new .nobody could tell me how to do it. there is no new to buy.I am happy for idea
gruß from the black forest meinolf
meinolf is offline   Reply With Quote
Old 11-12-2017, 08:47 PM   #8
notsolo
notsolo's Avatar
Here is an option for 73 van tilt, retro fitted into a 64. http://67-72chevytrucks.com/vboard/s...d.php?t=523901
notsolo is offline   Reply With Quote
