Old 11-11-2017, 02:22 AM   #1
chewychevy67
Has anyone mounted their radio antenna on driver side of cowl?
I am thinking of doing something custom and was wondering if anyone has. Mounted their antenna in the same spot as factory just on the driver side? Any issues with glare or vision? Just wanted to check before I commit to it. Also if you have a picture of it that would help as well. Thanks in advance.
chewychevy67 is offline   Reply With Quote
Old 11-11-2017, 02:27 AM   #2
In The Ten Ring
Re: Has anyone mounted their radio antenna on driver side of cowl?
I would suspect that would impede vision.
In The Ten Ring is offline   Reply With Quote
Old 11-11-2017, 03:11 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
Are you left handed ?
Jcfcamaro is offline   Reply With Quote
Old 11-11-2017, 05:06 AM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
my dad did that on his truck....its very annoying to be looking at it all the time....not to mention it looks out of place...I wouldn't do it myself
Old 11-11-2017, 06:05 AM   #5
chewychevy67
Yep that's what I figured. Thanks guys for the help. I'll leave it where it is.
Old 11-11-2017, 08:18 AM   #6
Actually, most things on the driver side allow for better vision, if you ask me. Not that a skinny antenna blocks much anywhere . On my first vehicles I put them on the driver side, don't recall my thinking. Then I went on the right just to be where factory mounts them. I always wondered why and figured just a cleaner path since instruments and controls are on the left. I guess it would be right there staring at you in the corner of your eye on the driver side. Never occurred to me back then, but nothing bothered me when I was young the way some things can now. One thing for sure, we are all used to them being on the right
Old 11-11-2017, 11:44 AM   #7
RichardJ
Mine is on the drivers side and has been there since I got it in the '80s. One reason for mounting on the left is an attempt to reduce breakage by delinquent kids walking down the side walk. One reason power antennas are so popular.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-11-2017, 09:22 PM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I agree with leaving it as is, but I'm left eye dominant. Makes a difference.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-12-2017, 07:18 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
I mounted my AM/FM antenna on the drivers side on my '67 K/10 Suburban. My reason was to be clear of the CB whip antenna on the passenger side rear. Obviously done a long time ago.
Old 11-12-2017, 11:07 AM   #10
mike16
maybe it has something to do with electrical interfearance with all of the electrical components on the driver side. or maybe draping the antenna cable through all the moving bits on the driver side would cause something to get caught up and jam.
mike16 is offline   Reply With Quote
Old 11-12-2017, 12:42 PM   #11
chewychevy67
I wanted to add a power antenna. That is my reason for swapping sides. With the a/c stuff on the passenger side there is no room for it. It's nicer to clean windows with the antenna down. Any pictures out there?
Old 03-01-2019, 12:00 AM   #12
chewychevy67
I'm still considering this. Any pictures of trucks with driver side antennas out there?
Old 03-01-2019, 07:47 AM   #13
72LB
72LB's Avatar
I'm removing mine, I'd rather have a smooth look.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 03-01-2019, 08:38 AM   #14
chewychevy67
That's kind of why I want to change to a power antenna. When the radio is not on it will be down and look cleaner.
Old 03-01-2019, 01:25 PM   #15
72LB
72LB's Avatar
I've never really looked in to a power antenna, not sure theres enough room.
Old 03-01-2019, 02:32 PM   #16
chewychevy67
There is if you remove the floor vent which is useless when you have ac anyway and is a rust trap.
Old 03-01-2019, 02:51 PM   #17
OL SKOOL
OL SKOOL's Avatar
Mine was mounted on the driver side originally. Thought it was kind of odd. .Never drove it bought as a basket case. When it goes back together it will be on pass. side. My ol s- 10 I frenched the antennae behind the door.
OL SKOOL is offline   Reply With Quote
