Old 11-12-2017, 10:44 AM   #1
04ls1gto
Ls swap oil pan- 71 c10 suburban
Planning my ls swap for upcoming winter and not sure if I need different oil pan. After some research the truck pan looks like it fits but not sure if clearance will be an issue as I'm lowered 3.5" in the front. Post up what pan your using, drop and what you have for clearance.
04ls1gto is offline   Reply With Quote
Old 11-12-2017, 04:14 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Ls swap out pan- 71 c10 suburban
Stock truck pan will usually hang down below the crossmember an inch or so, depending on mounts used. The GM muscle car pan is an inch or so shallower so usually ends up being even with it. That is the cheapest way to go since you can pick up the pan and everything to go with it brand new for only a couple hundred bucks. If youre lowering the truck, I would swap it out just for peace of mind.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-12-2017, 06:13 PM   #3
04ls1gto
I think I'll go with the GM pan. Roads around here are terrible. Not worth saving a few hundred bucks
Old 11-13-2017, 03:01 PM   #4
BamaBurb
Is this the pan you are reffering to?
https://www.summitracing.com/parts/nal-19212593
I am about to begin getting all the parts ready to swap my '71 burb over to an LS drivetrain and mine is lowered on bags. Nothing too drastic but its got 2.5 inch drop spindles and bags up front so it does sit pretty low when its dropped all the way down.
BamaBurb is offline   Reply With Quote
Old 11-14-2017, 10:39 AM   #5
scoot_mcgrute
That's the one that I used, works well!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
