Old 11-12-2017, 08:37 PM   #1
John H.
John H.'s Avatar
Tool Box Doors 67-72
These are left over from a few years of searching for the right pieces for my project.
2 doors
3 repro hinges
1 latch assembly
1 used lock W/O paw'& key (Not pictured)
all hinge mounting holes have been retapped and will function as original.
I think either one of these is a good start. I cut the one in half to better understand what we are up against in restoring these doors. This one I think would be the better of the two, just need to treat with zero rust, rust mort, POR15 or what ever you want and tack weld back up. I tried to keep where the rubber WS would be so. Both doors are pretty good around the pinch weld compared to others but the green top one has a little rust there. Also the green door has some dings which are under the trim and should be noted.
I don't want to separate.
Shipping would be about $22 conus
$325
John H. is offline   Reply With Quote
Old 11-12-2017, 08:38 PM   #2
John H.
John H.'s Avatar
Re: Tool Box Doors 67-72
Old 11-12-2017, 08:39 PM   #3
John H.
John H.'s Avatar
Old 11-12-2017, 08:40 PM   #4
John H.
John H.'s Avatar
Old 11-12-2017, 08:41 PM   #5
John H.
John H.'s Avatar
Old 11-24-2017, 11:08 PM   #6
John H.
John H.'s Avatar
Top
