![]() Join Date: Feb 2001
A/C wiring harness
Nice UNCUT wiring harness for A/C. Includes vacuum lines and firewall grommet. Some overspray on power wire near fuse panel. $50 shipped to you.
JQ
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Post Whore
![]() Join Date: Aug 2014
Re: A/C wiring harness
not to be a Dingleberry but I recently deleted my AC/Heater and in doing so learned that the only way to get the AC/Heater wiring harness out is to have to cut that pesky brown wire that disappears into the main wiring harness under the dash, everything else unplugged nicely, were you able to unplug yours somehow?
Brown wire does not have to be cut. There is a small metal tang on the female end of the wire connector. Use a small flat blade screw driver to depress this tang inside the plastic plug then the uncut wire can be pushed out of the plug. To reinstall, pry the metal tang back out and simply push wire into plug until it clicks.
![]() Join Date: May 2014
Is this from a 69 - 70 or 71 - 72? I believe they are different. I'm looking for a 71 - 72 style. Thanks
Wiring removed from a 1972 truck.
I'll take it. Please send PM with payment info. Thanks
