Old 11-13-2017, 10:53 PM   #1
Papastrick
69 C10 fuel line removal
I'm trying to remove my fuel line from the frame rail. Getting it out of the rear and center clips was easy. How do I get the line out of the front clip, it seems to be a different type.
Papastrick is offline   Reply With Quote
Old 11-14-2017, 06:43 AM   #2
In The Ten Ring
Re: 69 C10 fuel line removal
Anytime you are working with fuel lines, blow torch is your best bet. Failing that, go for shaped charges.
OK, done being silly. We really need pics to see what you are talking about.
I removed mine the first go, no experience and I was pretty inexperienced then with tools.
I had a little trouble getting one clip off, used a 1/2 inch drive ratchet and a ratcheting wrench....recall needing a neighbor's help for that. So it may be a 2 man job at one point. Get us pics.
In The Ten Ring is offline   Reply With Quote
Old 11-16-2017, 08:47 PM   #3
Papastrick
Thanks for the response. The clip I'm referring to is in the frame rail and the one furthest forward. I managed to pry it loose with a long screw driver and hammer.
Old 11-16-2017, 10:28 PM   #4
In The Ten Ring
Yours may have been rusted into place, I didn't have that problem.
Get us pics when you can, those are easy to load up on here. All you have to do is get those onto your computer (or phone I guess), get to this thread (without logging on), and start to post there. After you are directed to log on you will be able to post a pic using the options below this texting box. We don't need offsite pic hosting.
