11-13-2017, 11:06 PM | #1 |
63 c10, installing a LS engine
Im currently installing a 2002 6.0L into my 63 SWB C10. I purchased adjustable conversion plates from POL that allow 1/2" back and 2 1/2" forward for setting the engine. has anyone used these and has a quick picture of them? I cant seem to get them to position the engine forward enough, Thank you.
11-14-2017, 12:29 AM | #2 |
60-66 Nut
Re: 63 c10, installing a LS engine
11-14-2017, 01:25 AM | #3 |
But Found Her 25yrs Later!
Looks like your first post.
Welcome to the forums. . But yes, the section Captainfab links to in his post might get you a lot more replies.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-14-2017, 06:58 AM | #4 |
Post Whore
just from looking at that kit it looks like you'd have a bunch of adjustability. ...are your sure you bave the brackets on right? can you post a pic of how you have it installed?....
https://www.performanceonline.com/Ch...ethane-Mounts/ |
11-14-2017, 11:19 AM | #5 |
yes I have been watching this site for a few years, and now I have finally got back to working on my truck, I will post some pics later today and look forward to future involvement with this page, sounds like there are friendly people here with a wealth of knowledge!
11-14-2017, 12:20 PM | #6 |
Moderator
Welcome - There is the wisdom of the ages on this forum. Don't forget to check out the Frequently Asked Questions section also - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
AKA - FAQ
11-14-2017, 12:41 PM | #7 | |
I used the ICT brackets and Inline 6 frame stands and had to go to the 2" forward position to get firewall clearance. I'm a little further back than others I've seen but I can still pull the passenger valve cover and coil packs off so I'm happy |
11-14-2017, 12:45 PM | #8 |
Welcome & following along. Sounds like a build to watch and learn from.
11-14-2017, 07:41 PM | #9 |
Trying to upload pics from my phone, will get one of the kids to show me how tonight! lol. I will also upload pics of my new trany cross member I purchased that doesn't seem to have enough room for the stock drive shaft U joint. Will post specifics cause I could really use the help and im sure others will learn from this as Bomp suggested
11-14-2017, 11:01 PM | #10 |
Here are the pictures...
11-14-2017, 11:48 PM | #11 |
Post Whore
its hard to see what's going on but if your flipped the engine bracket would that help....what about instructions...what did they show as far as bracket mounting
11-14-2017, 11:51 PM | #12 |
Here is a pic of my drive shaft
11-14-2017, 11:55 PM | #13 |
2 of the holes are beveled so that you use a tapered mounting bolt into the block behind the motor mounts. if I flip the other way the beveled holes are in the wrong spot. I called POL and asked and he said that it was mounted correctly but another set of plates I purchased that said they put the motor into the stock location are the same as these ones in the full engine forward position.
11-15-2017, 12:09 AM | #14 |
Post Whore
I used ebay plates on mine that locate LS to stock location and all my holes were countersunk...they had both stock location and 2in forward
11-15-2017, 12:13 AM | #15 |
I may have to counter sink opposite holes myself, just wanted to make sure before I messed something up. I think ill send pics to POL as I'm sure they will look into the issues for me????
11-15-2017, 12:13 AM | #16 |
Post Whore
looks like your trans mount needs flipped around so the mount tab is on the backside of the crossmember
surely they'll help you out...was there a right and left side to the mounts?
11-15-2017, 12:15 AM | #17 |
60-66 Nut
I believe the trans crossmember needs to be flipped around so that the tube is forward of the mount. But I have never used an aftermarket trans crossmember.....plenty of factory crossmembers to be found that work just fine.
11-15-2017, 11:25 AM | #18 |
Never Ending Projects
Most trans mounts I have seen have the tab part to the rear, not forward like you have it. Like others, flip the crossmember around and you should be good to go.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-16-2017, 12:04 AM | #19 |
well word to the wise, the Performance On Line LS cross member and transmission mount will not work when installing a 2002 4L80-E transmission. As you can see in the pics I had to use 5/8" spacers to get the casting and bolts to stay high enough so that they didn't touch the tube. I also had to elongate the LS adjustable motor mount plates by 3/4". The issue I had was that the coil pack on the passenger side was about 1/4" from the fire wall and felt this was too close. I made the parts work but would do a little more research the next time.
11-16-2017, 02:09 AM | #20 |
Post Whore
keep in kind your driveline angles...you need about 3 deg downward angle on the engine and trans...it should match your rear diff you which should be about 3 deg upward angle.....
11-16-2017, 11:16 AM | #21 |
Yes, thank you for the reminder
11-16-2017, 01:25 PM | #22 | |
