Old 11-14-2017, 05:24 PM   #1
1957 Chief
Retired USAF
A new score...
Was out and about over the weekend and happened upon this gem. Its loaded to the gills with options. Still has the factory jack and all the jazz under the hood. And I got it cheap...
1957 Chief is offline   Reply With Quote
Old 11-14-2017, 06:09 PM   #2
TKCR
TKCR's Avatar
Re: A new score...
Very Nice Score!!
Old 11-14-2017, 06:30 PM   #3
cochino12
It followed me home?
cochino12's Avatar
Re: A new score...
Very cool, what are your plans for itit
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-14-2017, 09:25 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: A new score...
Looks like an '86 model year, built in Flint.
If it came through on second shift my guys put the front fenders on that truck.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-14-2017, 10:03 PM   #5
mongocanfly
mongocanfly's Avatar
Re: A new score...
great find...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-14-2017, 10:05 PM   #6
1957 Chief
Retired USAF
Re: A new score...
Heck who knows. It runs and drives and needs a lil tune up. I might take it to a dent doctor to see if they can do anything with the dent on the driver door. And then I might have one of my buddies see if he can cut/buff the paint.
K
Thats awesome brother, do you think they cross threaded any bolts? Ha ha.
Yes it is an 86 and I am surprised at how original and pristine it is. Doesn't seem to ragged out either.
Bubba
Old 11-15-2017, 05:56 AM   #7
TKCR
TKCR's Avatar
Re: A new score...
Can we see some interior pics?
Old 11-15-2017, 08:32 AM   #8
85/Silverado
85/Silverado's Avatar
Re: A new score...
Great find, Looks like it came Loaded too. The only thing I'd replace is the sliding back window. But that's just me. Hope to see it when your done dressing it up.
Congrats.
85/Silverado is offline   Reply With Quote
Old 11-15-2017, 09:57 AM   #9
Keith Seymore
Re: A new score...
Ha! Yes - it's likely. Be careful taking the radiator support/fender nose bolts out if you take the fender off.
1979-1986
1986 - 2019
Old 11-15-2017, 10:16 AM   #10
Mattchu60
Re: A new score...
Keith, just curious, but how fast did you guys install fenders on these things?
Mattchu60 is offline   Reply With Quote
Old 11-15-2017, 10:19 AM   #11
1957 Chief
Retired USAF
Re: A new score...
Absolutely. Its supposed to rain most of the day. Ill take some and get em uploaded as soon as I can.
Congrats.
Yes sir, I don't like the sliders. A solid glass is better in my opinion.
Ha ha, will do my brother!
Bubba
Old 11-15-2017, 11:12 AM   #12
DBLSPRT68
DBLSPRT68's Avatar
Re: A new score...
Nice Loaded Short bed! My 85 is close, but not all the options you have.
P.S. I bought my 85 extended cab from Bebe. It belonged too the guy who owns a utility trailer business (builds/sales). That was 2009 or 2010. I was living just south of Memphis at the time.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 11-15-2017, 12:00 PM   #13
Keith Seymore
Re: A new score...
Line rate at Flint Line 1 was 60 per hour, which is one every minute. (Line 2, Blazer and Suburban, was 36 jobs per hour).
You had about 45 seconds to install the fender and the other 15 second was walking to and from the job and reloading for the next one.
Fender-to-door gap was set using a little magnetic fixture which stuck to the door and had a little nylon tab of the desired thickness inserted into the gap. One fixture was stuck towards the top of the door (just below the A pillar) and one stuck to the bottom.
There were two guys per side working fender install, one at the front and one at the rear. They would take the fender off the overhead carrier, where it was presented upside down, already painted, emblems installed, trim installed and wheel liner installed. In one motion they would lift off the carrier, swing it toward the vehicle while flipping it upright and position it on the vehicle. The guy at the rear would jam it against the gap fixture and run the rearmost vertical bolt in; while he was doing that the guy in the front would start running in the nose bolts (to the radiator support, which was sitting loose on the chassis). The rear guy would open the door and run in the rearmost horizontal bolt and then hold the dogleg portion of the fender jammed against the gap fixture by wedging the aforementioned padded 4x4 between the tire and the wheel opening. The guy in the pit would run in the lower fender bolt.
These are Pontiacs but the process is the same: you can see a snippet at the 2:25 mark
https://www.youtube.com/watch?v=02eULOTP6CA
K
1979-1986
1986 - 2019
Old 11-15-2017, 12:13 PM   #14
Desert1957
Desert1957's Avatar
Re: A new score...
Originally Posted by keith seymore View Post
line rate at flint line 1 was 60 per hour, which is one every minute. (line 2, blazer and suburban, was 36 jobs per hour).
Fender-to-door gap was set using a little magnetic fixture which stuck to the door and had a little nylon tab of the desired thickness inserted into the gap. One fixture was stuck towards the top of the door (just below the a pillar) and one stuck to the bottom.
These are pontiacs but the process is the same: You can see a snippet at the 2:25 mark
https://www.youtube.com/watch?v=02eulotp6ca
k
wow
Desert
Desert1957 is offline   Reply With Quote
Old 11-15-2017, 04:59 PM   #15
Mattchu60
Re: A new score...
That blows my mind - i put my fenders on this summer and I think it took me about 20-30 min for each side.
Old 11-15-2017, 06:01 PM   #16
1957 Chief
Retired USAF
Re: A new score...
I know right where you are talking about brother. Small world.
Bubba
Old 11-15-2017, 06:42 PM   #17
frenchy51
frenchy51's Avatar
Re: A new score...
VERY nice and being an Arizona rig-I imagine pretty rust free. Great find!
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 11-16-2017, 09:43 PM   #18
1957 Chief
Retired USAF
Re: A new score...
Absolutely brother. Needs a lot of cleaning.
Bubba
Old 11-16-2017, 11:32 PM   #19
AJBert
Re: A new score...
I had an 83 that was fully loaded and the only thing I wearould change on your truck would be the 305 and the 3.08 gears. They might be nice for for cross country trips but aren't fun in the least for daily driving.
The 305, IMHO, is probably the worst engine ever put in a GM truck.
1972 Chevy K20
2000 Chevy Blazer ZR2
2006 Chevy Monte Carlo (wife's)
AJBert is offline   Reply With Quote
Old 11-17-2017, 05:51 AM   #20
TKCR
TKCR's Avatar
Re: A new score...
Bubba
That it does. Looks like the seat got swapped somewhere along the way. It looks like an older seat, maybe a 73-76. Is your seat adjuster in the front or off to the left of the seat?
Old 11-17-2017, 09:02 AM   #21
1957 Chief
Retired USAF
Re: A new score...
I was wondering about the seat, looked like an older style to me as well. Plus it is red. The handle is off to the left side. Towards the back.
Bubba
Old 11-17-2017, 09:36 AM   #22
TKCR
TKCR's Avatar
Re: A new score...
Bubba
l would say it’s a 73-76 poor mans foam
Old 11-17-2017, 01:31 PM   #23
Keith Seymore
Re: A new score...
Newer steering wheel, too.
..."poor man's foam..."
I'm glad you don't work in Marketing...
1979-1986
1986 - 2019
Old 11-17-2017, 03:00 PM   #24
44th Miss Inf
Re: A new score...
Nice truck. I like the charcoal on black. My 84 is the same
44th Miss Inf is offline   Reply With Quote
Old 11-17-2017, 09:50 PM   #25
1957 Chief
Retired USAF
Re: A new score...
Thanks brother.
I also noticed it has center bolt valve covers. I will have to run the engine numbers cause I think center bolt started in 87??
Bubba
