Truck and auto performance nut
Low hump removal/High hump install questions?
I'm doing a low to high hump swap(? or call it a low to high trans tunnel swap?) and had a couple of questions for those that have done it.
1st, I have cut out the low hump and loosely fitted the used high hump I got from a member here...are there any special details involving fitting it/drilling holes , etc. that I should be aware of? 2nd....whats everyone sealing there tunnels up with? Some type of narrow peel and stick insulation tape? Something like a tube of silicone or some seam sealer? Something else? I will also be reinstalling my B&M Truck Megashifter to the floor/hump that will get a lot of abuse, and wondered how much that might effect the sealing system used.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: Low hump removal/High hump install questions?
All I did was to notch the low cab for clearance..did not cut the entire opening out.I then fitted the high hump plate over it ....sealed it with camper shell tape and drilled with self tapping screws with rubber washers.
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
Thanks for the response. I thought about screws... but have a B&M Megashifter mounted to the new hump (as it was on the old hump)...meaning it would be taking some abuse and I feared the screws wouldn't hold up. I wound up bolting it down after running a large bead of seam sealer in what I was guessing a groove around the inside of the hump made for sealant.
