Old 11-15-2017, 05:56 PM   #1
Drummerboy
Drummerboy's Avatar
Are these stock height spindles?
I'm going to go ahead and order a power disc brake kit for my '68. My truck was lowered with springs and shocks but I'm not sure if my spindles are stock or lowered. I believe they are stock. Can someone please help me confirm what I have?
Drummerboy is offline   Reply With Quote
Old 11-15-2017, 06:19 PM   #2
raggedjim
raggedjim's Avatar
Re: Are these stock height spindles?
I would guess Yes since you have drum brakes.
Rg
raggedjim is offline   Reply With Quote
Old 11-15-2017, 07:52 PM   #3
Mike C
Mike C's Avatar
There are no drum brake drop spindles is what he means.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-15-2017, 07:59 PM   #4
Drummerboy
Drummerboy's Avatar
Ahhh.... Duh. I wasn't sure because I'm putting disc brakes on these stock spindles.
Old 11-15-2017, 10:41 PM   #5
Chevy4Life
Chevy4Life's Avatar
You will need new spindles for Disc brakes. I think there is some oddball kit that works with the drum but just get the correct Disc spindle. Stock or Lowered depending on what you are going for. Also it looks like you are riding on the bumps stops right now so you definitely need a taller set of springs.
Chevy4Life is online now   Reply With Quote
Old 11-16-2017, 11:00 AM   #6
chewychevy67
You can't get lowered drum spindles but you can get 6 bolt discs that work with the drum spindles now. https://www.summitracing.com/parts/ssb-a126-71. I used this kit. Went together nicely.
chewychevy67 is offline   Reply With Quote
