Old 11-15-2017, 09:28 PM   #1
Zachary17
Zachary17's Avatar
Angry When Trying to fix something only makes it worse
So over the last month or so my c10 started running hot.so i Checked the coolant level it was fine.but it had a green brownish color so I decided to flush the coolant system BIG MISTAKE.i drained the coolant.put distilled water and vinegar in the radiator ran it for 2 days with the vinegar in there.And next day I flushed the radiator and put in new antifreeze and a new thermostat all was good till next day when the freeze plugs started leaking.one behind the flex plate and motor mount.so.out she comes!
Zachary17 is offline   Reply With Quote
Old 11-15-2017, 10:08 PM   #2
mongocanfly
mongocanfly's Avatar
Re: When Trying to fix something only makes it worse
"When Trying to fix something only makes it worse"
story of my life.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-16-2017, 07:48 AM   #3
homemade87
I know what your saying but I always look at it this way . It was going to happen anyway and I would rather it happen when I have better control of the situation rather than the freeze plug be rusted to almost nothing before you detect it and it blows out and dumps all the fluid when your 100 miles from home . You did speed up the process a little but I always feel lucky when I fine a problem before it puts me in a bad situation .
SO not a big mistake in my eyes . Get some brass freeze plugs to replace them .
homemade87 is offline   Reply With Quote
Old 11-16-2017, 10:26 PM   #4
Zachary17
Zachary17's Avatar
So today I got the engine and trans out and on the stand.got all the old rusted freeze plugs.and found out why I had brown coolant.
Old 11-16-2017, 10:30 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
I'll play. So why did you have brown coolant?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-16-2017, 10:32 PM   #6
Zachary17
Zachary17's Avatar
So Finally after a hour of pressure washing the inside of the block I got all the mud out and then I realized the mess I had made.
Old 11-16-2017, 10:42 PM   #7
Zachary17
Zachary17's Avatar
there was about 2 to 3 inches of mud in block.probably had something to do with the PO running water in it.
