Old 11-16-2017, 01:19 PM   #1
70 cst
70 cst's Avatar
Mystery wiring harness
Wondering if any of you guys know what this harness goes to? It looks original to the truck but I can't find anything that it fits. Truck is a 72 custom 10 without air and a 307 v8 and 350 turbo transmission. The 2nd pic shows it coming into the cab and plugs into a relay. The 3rd pic shows the plugins.
70 cst is offline   Reply With Quote
Old 11-16-2017, 01:51 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Mystery wiring harness
Looks like A/C connections
Jcfcamaro is offline   Reply With Quote
Old 11-16-2017, 01:55 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's another picture and it's the harness for the TCS wiring. This was a pitiful attempt from GM to respond to the emissions mandate that the EPA forced on the manufacturers in the early 70s. It's called "transmission controlled spark" and
there is plenty of info on the forums about it, also google has lots of information.
Most of the owners of our trucks have ripped it out since the engines run better without it.
Name:  Horn and TCS relays.JPG
Some of the relays were mounted on the engine side firewall.
Name:  TCS relays.jpg
You don't have AC but the AC relay was mounted in the airbox if I recall correctly. That would be the only other stock installed harness.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-16-2017, 05:18 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
VetteVet is correct (not that he needs me to back him up) "just sayin"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-16-2017, 06:46 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a 1972 GMC that had the "Spark Knock" wiring as well. I removed it all without any problems.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-16-2017, 07:03 PM   #6
Grandpas 72
That wiring harness is a transmission control spark harness. It plugs into the TCS vacuum solenoid.
I hope this helps.
....the green wire goes to the temp sensor under the exhaust manifold on the drivers side I believe.
Grandpas 72 is offline   Reply With Quote
Old 11-17-2017, 12:52 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I hope this helps.
I had the TCS on my 71, located on the engine side firewall. One unit is a relay and the other is a delay.
Interesting you should mention the green wire. What I found was a dark green wire that had been cut, and to-date I haven't been able to ID it. At any rate, I give up, what's a temp. sensor under an exhaust manifold?
My truck also had a dark green wire that ran to the temp. sensor that fits into the head. But the wire came off the driver's side of the firewall block.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-17-2017, 03:32 AM   #8
70 cst
70 cst's Avatar
Guys I really appreciate the responses. The original engine is gone along with the emissions equipment. I wanted to remove this harness if it didn't have a reason to stay but I didn't want to remove something I may need.. I will go ahead and remove it and put a plug in that hole.
