Old 11-16-2017, 01:27 PM   #1
Popp55
Wiring electric fan.
So I just need help on how to wire in my electric fan. I put a new motor in a few months back and now when I give the truck gas my fan flexs too much and starts to hit. I've already put a spacer on it and it didn't help. So I decided an electric fan would be my next option. This truck was a project from my grandfather for the both of us until he passed away. So I've been going at it with basic knowledge but wiring is not my strong suit. I'm just curious on where I can connect it as far as the fuse box and if I should run it to constant power with an on/off switch or just power to the ignition if that makes sense.. truck is a 1972 C10.. thanks!
Popp55 is offline   Reply With Quote
Old 11-16-2017, 01:45 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Wiring electric fan.
Hey neighbor I’m in Riverside also! Thinking about using an electric fan on my 68 so curious to see how others have done it as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-16-2017, 02:21 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a simple diagram that should help.
1.The wire from the battery goes to a 30 amp fuse, then to no. 30 on the relay.
2.The wire from the fan which goes to the relay is connected to no 87 on the relay.
3.The wire from the manifold sensor is a ground wire controlled by the coolant temperature is grounded and it is connected to no. 85 on the relay.
4.The wire from the ignition switch "on power" goes to no.86 on the relay.
5.There is a number 87A terminal on most of these relays but it isn't used in this app.
The manual override switch is just a ground to the number 85 terminal to override the sensor control you need in the manifold.
These kits usually come with a fan kit as a total package. The override switch
may not be included but it is simple to install.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-16-2017, 05:58 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wiring electric fan.
Install it on a relay and have it come on by temp probe you stick in the fins of your radiator. You could also put a manual switch in line to over ride the probe if you need it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-17-2017, 12:39 PM   #5
cleszkie
cleszkie's Avatar
I am all for electric fans (I run twin 2300 cfm Derale units). However, have you considered replacing your belt driven flex fan with a stock steel rigid fan? This will eliminate the fan interference with the shroud at high RPM. Seems like a much easier fix to your problem (I am assuming that cooling is not the issue). If it ain't broke, don't fix it
cleszkie is offline   Reply With Quote
Old 11-17-2017, 02:54 PM   #6
nikwho
nikwho's Avatar
I am running this controller, with the temp switch installed in the water pump. It's powered with a constant 12v source, so after the truck shuts down, the fan continues to run until the coolant is below 180°.
http://derale.com/products/electric-...t-11-32-detail
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 11-17-2017, 03:47 PM   #7
davepl
davepl's Avatar
If this is a reasonably stock truck why not put on a good 7-blade fan with a clutch? That's what my big block has, works for me!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-17-2017, 04:20 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I agree. Also, pics should help determine why your fan is flexing to the point of hitting something. That's not a common problem.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
