Active Member
![]() Join Date: Oct 2017
WTB Neutral Safety Switch Terminal End Manual Trans
I’m looking for the terminal end for my neutral safety switch on my ‘77 Chevy. The PO just butt connected the wires to by-pass the faulty switch.
The wires going to it are purple and purple with a white tracer. I had another harness saved from a’78 with four speed but somebody did the same thing! I couldn’t believe it, so I need the terminal end that the two purple wires go into or that terminal end with the wires in it so I can just solder it on to the existing wires. I’m not sure if anybody can help but I sure would appreciate any. Please see the pictures for reference Thanks. |
Active Member
Re: WTB Neutral Safety Switch Terminal End Manual Trans
This is a picture of the plug I’m looking for.
![]() Join Date: Jun 2009
I have one $22 shipped. Most of the time these are bypassed just like yours.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
![]() Join Date: Jan 2002
if you cant find one ??? ck napa -i believe they have a universal one that might work ? so many things are being discontinued these days ?? good luck -im doing one that was bypassed but everything is still there !
Active Member
Thanks, I appreciate it. I will check. Your lucky, nobody wants to fix things right these days!
Do you have a part number for the switch you have pictured? I need something to put on my 78 that I have converted to a manual trans.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Active Member
Active Member
Part number for switch is 336248.
#9 | |
Active Member
Bolt-336250 Nut-336296 |
Thanks for the info man!
Active Member
So for anyone else who might be looking looks like the 336248 was replaced with 14013141 which was replaced with 14074333. All are discontinued.
Other options: Standard motor products NS12 -discontinued AC Delco D2211A -discontinued. I did go ahead an get the bolt off eBay though. There are some switches out there but man they are pricey imo. You can get an 85+ one for like $11 but most of these are $40 or more. Guess I'll have to bite the bullet on one eventually.
#13 |
Shipped out today
#14 |
If anyone finds this later I got a switch an installed it today. The pigtail off the neutral safety switch from the column fit this switch perfectly. The wires were even long enough to reach it without modifying them.
