Old 11-17-2017, 05:43 PM   #1
SimonTek
Lower Control Arm U-Bolt size
I strugged to find this info, so posting it here.
Control Arm U-Bolt Center to Center 2.13"
Control Arm U-Bolt Length 3.44"
Control Arm U-Bolt Thread Size 9/16"-12 UNC-2A
1969 Chevrolet C20 Longbed
I-6 250, SM465
SimonTek is offline   Reply With Quote
Old 11-17-2017, 06:26 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Lower Control Arm U-Bolt size
Stock is 1/2" if I remember right ,While you have them apart upgrade to Dorman 13503 which are 9/16 .
https://www.summitracing.com/parts/r...SABEgKJvvD_BwE
Grumpy old man is offline   Reply With Quote
Old 11-17-2017, 07:12 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I used the 9/16" Dorman U-bolts listed above and didn't even have to drill out the holes in the Crossmember for them to fit. Great upgrade for cheap!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-17-2017, 07:27 PM   #4
68is4me
68is4me's Avatar
I also used the bigger 9/16 bolts. Also available from gm p/n 345970 (9/16-12x 3 5/32). I am not a big fan of dorman stuff.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 11-17-2017, 11:07 PM   #5
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I had the 9/16" bolts stock. I know it was original, because it still had the riveted ball joints at 210k miles. I'll bet that the truck lost 20 pounds of dirt and grease when I rebuilt that front end.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
bolt sizes, control arm
