Old 11-18-2017, 12:35 AM   #1
reb162
reb162's Avatar
New AC Fan Shroud Needed for Vintage Air?
This might be stupid, but if I'm installing a Vintage Air kit into a non-AC truck, do I need to get an AC Shroud to replace my non-AC shroud I currently have. I can't find discussion on this anywhere and the install directions do not mention anything about it. I imagine the condensor of the vintage air will not fit under a non A/C shroud?
If it matters, no matter which shroud is needed, I plan to delete the engine fan and install the Jeep Electric Fan Mod using the OEM shroud (either AC or non-AC).
1971 Chevy C-10
Currently is rust repair
reb162 is offline   Reply With Quote
Old 11-18-2017, 07:44 AM   #2
Mr Handy
Mr Handy's Avatar
Re: New AC Fan Shroud Needed for Vintage Air?
The ac condenser goes in front of the rad, not behind. I just installed a VA system in my truck a couple months ago. You will need to drill a couple of holes in the core support under the battery tray for the lines to pass through.
Mr Handy is offline   Reply With Quote
Old 11-18-2017, 07:48 AM   #3
RustyBucket
RustyBucket's Avatar
The condensers on both of my trucks are attached to the fronts of the radiator supports and don't interfere with the fan shrouds. The Blazer is factory A/C, 4 core stock radiator & the GMC is aftermarket A/C, aluminum radiator. Both have 7 blade GM clutch fans.... both cool fine.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 11-18-2017, 09:10 AM   #4
reb162
reb162's Avatar
Great...thanks for the info guys. So it seems my existing non AC shroud will work fine. Did the factory AC condenser also go on the front of the radiator? If so, what was the reason for a different shroud for AC versus non AC from the factory? Just curious.
1971 Chevy C-10
Old 11-18-2017, 11:24 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep, condenser is in front of the radiator support on the passenger side. FWIW, I'm not aware of a different shroud for A/C trucks...... Different for 4WD vs 2WD, yes.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-18-2017, 11:31 AM   #6
reb162
reb162's Avatar
Interesting. I was going by LMC which lists different shroud part numbers for AC versus non-ac, a third for 4wd and a fourth for big block.
1971 Chevy C-10
Old 11-18-2017, 11:36 AM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
With AC you will have a bigger fan (usually with a clutch), so the shroud will be different from a non-AC shroud.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-18-2017, 02:14 PM   #8
B. W.
B. W.'s Avatar
The factory A/C shroud is about 1" shorter than the non-A/C shroud. I believe it is shorter in order to clear the compressor & belt (just a guess).
B. W. is offline   Reply With Quote
