Old 11-18-2017, 02:43 PM   #1
Man With A Gun
Man With A Gun's Avatar
Fuel gauge indicates 1/4 tank when it's actually empty
I have the dual tank setup so I can let it go "dry" (actually there's only 18.5 gallons that can be added so there is a 1.5 reserve).
But this happens when the fuel gauge is showing around 1/4 tank.
Does this mean my sending unit is bad?
Bad ground or connection?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 11-18-2017, 05:31 PM   #2
Dead Parrot
Re: Fuel gauge indicates 1/4 tank when it's actually empty
If the gauge reads 1/4 when fuel exhausted on both sides, probably bad gauge. If it goes to E on one side and 1/4 on the other, probably bad sender on 1/4 side.
My original gauge would read E with a few gallons in the tank. One side reached E with about 4 left, the other had about 2. When that gauge died, the replacement reads E with very little left in the tank.
When I run my 20 gallon tanks dry, I can often get 20~21 gallons in them.
Dead Parrot is offline   Reply With Quote
Old 11-21-2017, 02:05 PM   #3
wilkin250r
wilkin250r's Avatar
If the gauge functions (meaning a full tank shows full, and the gauge drops as the level drops), it means you've got some other resistance in the circuit.
As Dead Parrot suggests, what does the gauge read on the other tank? Does it work properly, or does the other tank show 1/4 tank at empty also?
Might be corroded wiring, might be a poor ground connection, heck it might be a poor connection ANYWHERE in that circuit adding a little more resistance than it should.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
